[Live-demo] Re: [OSGeo] #758: rasdaman failing to build
Cameron Shorter
cameron.shorter at gmail.com
Thu Aug 18 07:51:36 EDT 2011
Peter, Michael,
Our final build for OSGeoLive is this Monday 22 August, and if we can't
get the application debugged, we will need to consider removing it for
this release.
If you do want rasdaman on the upcoming osgeo-live release, can you
please have a look and see if you can work out what is not working ASAP.
Logs and virtual machine are here:
http://live.osgeo.org/dev/build/
> Reporter: camerons | Owner: sac@…
> Type: defect | Status: new
> Priority: major | Milestone:
> Component: Systems Admin | Keywords: 5.0 rasdaman
> Hi,
> install_rasdaman.sh is still failing to build in 5.0rc1.
> rasmgr_config.cc: In member function<E2><80><98>const char*
> Configuration::makeLogFileName(
> const char*)<E2><80><99>:
> rasmgr_config.cc:555:64: error:<E2><80><98>mkdir<E2><80><99> was not
> declared in this scope
> make[2]: *** [rasmgr_config.o] Error 1
> make[2]: Leaving directory `/tmp/build_rasdaman/rasdaman/rasmgr'
> make[1]: *** [install-recursive] Error 1
> make[1]: Leaving directory `/tmp/build_rasdaman/rasdaman/rasmgr'
> make: *** [install-recursive] Error 1
> ERROR: package install failed.
> thanks,
> Hamish
Cameron Shorter
Geospatial Director
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo
