[Live-demo] Re: [OSGeo] #758: rasdaman failing to build
Peter Baumann
p.baumann at jacobs-university.de
Thu Aug 18 08:24:20 EDT 2011
Cameron-
we've spotted this now: due to a version upgrade the file name has changed
(which contains the version).
A version which contains a fix of the compile issue has been provided at the old
place (ie, name) now.
We like to think that it works now, please let us know of any issues attempting
to persist.
-Peter
On 08/18/2011 01:51 PM, Cameron Shorter wrote:
> Peter, Michael,
> Our final build for OSGeoLive is this Monday 22 August, and if we can't get
> the application debugged, we will need to consider removing it for this release.
> If you do want rasdaman on the upcoming osgeo-live release, can you please
> have a look and see if you can work out what is not working ASAP.
> Logs and virtual machine are here:
> http://live.osgeo.org/dev/build/
>> Reporter: camerons | Owner: sac@…
>> Type: defect | Status: new
>> Priority: major | Milestone:
>> Component: Systems Admin | Keywords: 5.0 rasdaman
>> Hi,
>> install_rasdaman.sh is still failing to build in 5.0rc1.
>> rasmgr_config.cc: In member function<E2><80><98>const char*
>> Configuration::makeLogFileName(
>> const char*)<E2><80><99>:
>> rasmgr_config.cc:555:64: error:<E2><80><98>mkdir<E2><80><99> was not
>> declared in this scope
>> make[2]: *** [rasmgr_config.o] Error 1
>> make[2]: Leaving directory `/tmp/build_rasdaman/rasdaman/rasmgr'
>> make[1]: *** [install-recursive] Error 1
>> make[1]: Leaving directory `/tmp/build_rasdaman/rasdaman/rasmgr'
>> make: *** [install-recursive] Error 1
>> ERROR: package install failed.
>> thanks,
>> Hamish
Dr. Peter Baumann
- Professor of Computer Science, Jacobs University Bremen
www.faculty.jacobs-university.de/pbaumann
mail: p.baumann at jacobs-university.de
tel: +49-421-200-3178, fax: +49-421-200-493178
- Executive Director, rasdaman GmbH Bremen (HRB 26793)
www.rasdaman.com, mail: baumann at rasdaman.com
tel: 0800-rasdaman, fax: 0800-rasdafax, mobile: +49-173-5837882
"Si forte in alienas manus oberraverit hec peregrina epistola incertis ventis dimissa, sed Deo commendata, precamur ut ei reddatur cui soli destinata, nec preripiat quisquam non sibi parata." (mail disclaimer, AD 1083)
More information about the Live-demo
