[Live-demo]Does your app work on the new OSGeo-Live V4.5 Alpha2?
Cameron Shorter cameron.shorter at gmail.com
Sun Feb 6 19:33:38 EST 2011
Jonathan,
Great to hear about your the screenshots you have been collecting. If
these are for quickstarts, it would be good to get these included into
subversion, and then link into the appropriate documentation (and
hopefully save someone else the effort).
To use subversion, look here:
http://wiki.osgeo.org/wiki/Live_GIS_Disc#Subversion
You will need to let me know you osgeo user id so that I can set up up
with write access. OSGeo User id is set up here:
http://www.osgeo.org/osgeo_userid
On 07/02/11 11:07, Jonathan Roach wrote:
> Hi all,
> I have been doing some testing in the previous live DVD acquiring
> screen shot.
> I have not being able to make them available just yet due to machine
> trouble but I should be able to assist in checking the application
> list and updating the documentation of the latest OSGeo-live build.
> Please let me know.
> Regards
> *Jonathan K. Roach*
> */Geographic and Land Information Systems Officer /*
> /Division: Land Use and Sustainability/
> /Branch: Strategic Land Use Planning (Design and Technical Group/GIS)/
> 1 Belgrave Street Manly NSW 2095 | PO Box 82 Manly NSW 1655 | Direct
> 9976 1612 |
> Switch 9976 1500 | Fax 9976 1400 | jonathan.roach at manly.nsw.gov.au
> <mailto:Suzanne.Biskup at manly.nsw.gov.au>| www.manly.nsw.gov.au
> <file:///%5C%5Cstore2%5Croot%5CSoftware%5CTemplates%5CTEST%5Cwww.manly.nsw.gov.au>
> *From:*live-demo-bounces at lists.osgeo.org
> [mailto:live-demo-bounces at lists.osgeo.org] *On Behalf Of *Cameron Shorter
> *Sent:* Sunday, 6 February 2011 10:50 AM
> *To:* live-demo at lists.osgeo.org
> *Subject:* Re: [Live-demo]Does your app work on the new OSGeo-Live
> V4.5 Alpha2?
> *Importance:* High
> I'm looking for volunteers to help us determine which applications
> have been installed successfully on the latest OSGeo-Live build.
> In particular, we need to keep track of which version has been
> installed successfully.
> Who is available to try out applications on the latest VM? At some
> point, a representative from each application should run their
> application on the VM and confirm it works as expected. We will ask
> for more comprehensive testing after our UAT deadline of 21 Feb 2011.
> I've written up the process to follow to collect status here:
> http://wiki.osgeo.org/wiki/Live_GIS_Review#Application_Review
>   Application Review
>     * Download the latest ISO or Virtual Machine from
>       http://live.osgeo.org/dev/build
>     * Virtual Machines will need to be uncompressed with 7zip for
>       windows <http://www.7-zip.org/> or 7zip for unix
> 7z x file.7z
> For each application:
>     * Verify that you can select the application from the pull down menu.
>     * Find out what version of the application has been installed, and
>       insert the version number into the "installed version" column of
>       the Status spreadsheet
>       <https://spreadsheets.google.com/ccc?key=0Al9zh8DjmU_RdGIzd0VLLTBpQVJuNVlHMlBWSDhKLXc&hl=en_GB#gid=8>
>     * Run the application and see if it works. If the Quickstart
>       exists, try following the Quickstart instructions.
> Note any errors that you find in the issue tracker using the following:
>     * OSGeo-Live issues are reported here:
>       https://trac.osgeo.org/osgeo/report/10
>     * Set "Component" = "LiveDVD"
>     * For "Keywords", add the base release number, and the application
>       id used in the Status Spreadsheet
>       <https://spreadsheets.google.com/ccc?key=0Al9zh8DjmU_RdGIzd0VLLTBpQVJuNVlHMlBWSDhKLXc&hl=en_GB#gid=8>.
>       Eg: "4.0, geoserver". Don't use "4.0rc1, geoserver".
> On 06/02/11 08:18, Alex Mandel wrote:
> On 02/04/2011 08:33 PM, Alex Mandel wrote:
>     I just started the Alpha2 build @r5513. I am well aware there are some
>     known outstanding issues but since the last build only made it as far as
>     Sahana we wanted to make sure that we get some error information for the
>     rest of the packages.
>     Look for build logs and possibly a downloadable vm in approx 12 hours
>     (Build is mostly running while I'm asleep, it doesn't actually take 12
>     hours, much closer to 2-3 hours).
>     Thanks,
>     Alex
> Came out better this time, still some work to do of course. Logs an vmdk
> file are up. We also now have a stable url to help you get the latest
> dev build when they become available. It's a redirect for now but should
> always get you to the right place.
> Thanks,
> Alex
> Live-demo mailing list
> Live-demo at lists.osgeo.org  <mailto:Live-demo at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/live-demo
> Cameron Shorter
> Geospatial Director
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they
> are addressed. Re-transmitting or re-publishing the content of this
> email in any media format without the express permission of the Author
> is strictly prohibited.
> If you have received this email in error please notify Manly Council
> immediately. Information transmitted via email may be subject to
> corruption by the process. Information contained in this email should
> not be relied upon where loss, damage or injury is possible. Verified
> information should be obtained in writing directly from the authorised
> Council officers.
Cameron Shorter
Geospatial Solutions Manager
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110207/3ba9623f/attachment.html
More information about the Live-demo mailing list
