[Live-demo]Does your app work on the new OSGeo-Live V4.5 Alpha2?
Angelos Tzotsos
gcpp.kalxas at gmail.com
Thu Feb 10 18:26:20 EST 2011
Hi all,
A first review of the OSGeo-Live 4.5 alpha 2 has just finished.
This is the list of issues that were found and commented on the status
spreadsheet:
Failure to launch:
52nSOS --> The desktop link does not provide any feedback that the
service started.
Deegree --> The link does not provide any feedback that the service started.
Geomajas --> http link not working
Geonetwork --> Application link not working in Firefox (service start
and stop links work fine)
Rasdaman --> Not working. Build error?
Sahana --> Application link not working
Issues with versions:
Deegree --> Still in 2.x version
GDAL --> later version (1.7.3) than proposed (1.7.2) but seems it would
be great to have 1.8.0
Geonetwork --> Version completely outdated. The installed version
(2.4.2) is older than the one installed in OSGeo Live 4.0.1!
Mapfish --> still in version 1.2 instead of 2.0
Openlayers --> still in version 2.9.1 instead of 2.10
Osgearth --> still in version 1.4.1 instead of 2.0
OSSIM --> installed version 1.8.3. Need to update to 1.8.6 since this
was used in OSGeo Live 4.0.1
uDig --> installed version 1.2.0 instead of latest 1.2.1
All applications were tested if running, but quickstarts not tested in
this review. Web services were tested with GetCapabilities only.
Regards,
Angelos
On 02/06/2011 01:50 AM, Cameron Shorter wrote:
> I'm looking for volunteers to help us determine which applications
> have been installed successfully on the latest OSGeo-Live build.
> In particular, we need to keep track of which version has been
> installed successfully.
> Who is available to try out applications on the latest VM? At some
> point, a representative from each application should run their
> application on the VM and confirm it works as expected. We will ask
> for more comprehensive testing after our UAT deadline of 21 Feb 2011.
> I've written up the process to follow to collect status here:
> http://wiki.osgeo.org/wiki/Live_GIS_Review#Application_Review
> Application Review
> * Download the latest ISO or Virtual Machine from
> http://live.osgeo.org/dev/build
> * Virtual Machines will need to be uncompressed with 7zip for
> windows <http://www.7-zip.org/> or 7zip for unix
> 7z x file.7z
> For each application:
> * Verify that you can select the application from the pull down menu.
> * Find out what version of the application has been installed, and
> insert the version number into the "installed version" column of
> the Status spreadsheet
> <https://spreadsheets.google.com/ccc?key=0Al9zh8DjmU_RdGIzd0VLLTBpQVJuNVlHMlBWSDhKLXc&hl=en_GB#gid=8>
> * Run the application and see if it works. If the Quickstart
> exists, try following the Quickstart instructions.
> Note any errors that you find in the issue tracker using the following:
> * OSGeo-Live issues are reported here:
> https://trac.osgeo.org/osgeo/report/10
> * Set "Component" = "LiveDVD"
> * For "Keywords", add the base release number, and the application
> id used in the Status Spreadsheet
> <https://spreadsheets.google.com/ccc?key=0Al9zh8DjmU_RdGIzd0VLLTBpQVJuNVlHMlBWSDhKLXc&hl=en_GB#gid=8>.
> Eg: "4.0, geoserver". Don't use "4.0rc1, geoserver".
> On 06/02/11 08:18, Alex Mandel wrote:
>> On 02/04/2011 08:33 PM, Alex Mandel wrote:
>>> I just started the Alpha2 build @r5513. I am well aware there are some
>>> known outstanding issues but since the last build only made it as far as
>>> Sahana we wanted to make sure that we get some error information for the
>>> rest of the packages.
>>> Look for build logs and possibly a downloadable vm in approx 12 hours
>>> (Build is mostly running while I'm asleep, it doesn't actually take 12
>>> hours, much closer to 2-3 hours).
>>> Thanks,
>>> Alex
>> Came out better this time, still some work to do of course. Logs an vmdk
>> file are up. We also now have a stable url to help you get the latest
>> dev build when they become available. It's a redirect for now but should
>> always get you to the right place.
>> Thanks,
>> Alex
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
> Cameron Shorter
> Geospatial Director
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110211/65e5b69d/attachment.html
More information about the Live-demo
