[Live-demo] 4.5alpha3 Built - Mapfish
Cameron Shorter cameron.shorter at gmail.com
Sat Feb 19 15:09:17 EST 2011
Thanks Bruno for the fix,
Could someone who has a VM downloaded please do a "svn update; cd
gisvm/bin; sudo ./install_mapfish.sh"
Then confirm that mapfish now works.
On 20/02/11 01:45, Bruno Binet wrote:
> This should now be fixed: I've tested on the osgeolive vm and mapfish
> install now went well.
> On 19 February 2011 11:46, Brian Hamlin<maplabs at light42.com>  wrote:
>> here is the sample script that may be the trouble
>> Brian Hamlin
>> planetwork.net
>> OSGeo California Chapter
>> (415) 717-4462 cell
>> On Feb 19, 2011, at 2:20 AM, Bruno Binet wrote:
>>> I'll try to look at it today. I am currently downloading the vm since
>>> I haven't found anything relevant in the logs...
>>> On 18 February 2011 20:37, Cameron Shorter<cameron.shorter at gmail.com>
>>> wrote:
>>>> Hi Bruno,
>>>> Did you pick up on this error report from Brian?
>>>> Could you please look into it and try to have it fixed before Sunday 21
>>>> Feb
>>>> when Alex is scheduled to create our first release candidate.
>>>> The logs and Virtual Machine can be downloaded here:
>>>> http://live.osgeo.org/dev/build
>>>> Please let Brian know when you have fixed the script. He should be able
>>>> to
>>>> verify it works in the latest vm for you (or alternatively you can
>>>> download
>>>> a vm yourself).
>>>> You can usually find Brian (alias dbb) at irc://freenode.net#osgeolive
>>>> On 16/02/11 13:09, Brian Hamlin wrote:
>>>>> Hi Mapfish Team Representatives
>>>>>   it appears that poi_osm data table in postgres failed to load in the
>>>>> build process
>>>>> Please check the logs and/or the virtual machine image
>>>>>   hth
>>>>>    -Brian
>>>>> Brian Hamlin
>>>>> planetwork.net
>>>>> (415) 717-4462 cell
>>>>> _______________________________________________
>>>>> Live-demo mailing list
>>>>> Live-demo at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
>>>> Cameron Shorter
>>>> Geospatial Director
>>>> Tel: +61 (0)2 8570 5050
>>>> Mob: +61 (0)419 142 254
>>>> Think Globally, Fix Locally
>>>> Geospatial Solutions enhanced with Open Standards and Open Source
>>>> http://www.lisasoft.com
>>> Bruno Binet
>>> Camptocamp France SAS
>>> Savoie Technolac, BP 352
>>> 73377 Le Bourget du Lac, Cedex
>>> Mail : bruno.binet at camptocamp.com
>>> http://www.camptocamp.com
Cameron Shorter
Geospatial Director
More information about the Live-demo mailing list
