[Live-demo] 4.5alpha3 Built - Mapfish
Angelos Tzotsos
gcpp.kalxas at gmail.com
Sat Feb 19 15:14:25 EST 2011
Hi all,
I just did an update on the vm as Cameron suggested and Mapfish does not
start.
The script log shows an error about not being able to update some db
table, being accessed by other users.
After trying the Mapfish icon, I get an error that the page is not found.
Regards,
Angelos
On 02/19/2011 10:09 PM, Cameron Shorter wrote:
> Thanks Bruno for the fix,
> Could someone who has a VM downloaded please do a "svn update; cd
> gisvm/bin; sudo ./install_mapfish.sh"
> Then confirm that mapfish now works.
> On 20/02/11 01:45, Bruno Binet wrote:
>> This should now be fixed: I've tested on the osgeolive vm and mapfish
>> install now went well.
>> On 19 February 2011 11:46, Brian Hamlin<maplabs at light42.com> wrote:
>>> here is the sample script that may be the trouble
>>> Brian Hamlin
>>> planetwork.net
>>> OSGeo California Chapter
>>> (415) 717-4462 cell
>>> On Feb 19, 2011, at 2:20 AM, Bruno Binet wrote:
>>>> I'll try to look at it today. I am currently downloading the vm since
>>>> I haven't found anything relevant in the logs...
>>>> On 18 February 2011 20:37, Cameron Shorter<cameron.shorter at gmail.com>
>>>> wrote:
>>>>> Hi Bruno,
>>>>> Did you pick up on this error report from Brian?
>>>>> Could you please look into it and try to have it fixed before
>>>>> Sunday 21
>>>>> Feb
>>>>> when Alex is scheduled to create our first release candidate.
>>>>> The logs and Virtual Machine can be downloaded here:
>>>>> http://live.osgeo.org/dev/build
>>>>> Please let Brian know when you have fixed the script. He should be
>>>>> able
>>>>> to
>>>>> verify it works in the latest vm for you (or alternatively you can
>>>>> download
>>>>> a vm yourself).
>>>>> You can usually find Brian (alias dbb) at
>>>>> irc://freenode.net#osgeolive
>>>>> On 16/02/11 13:09, Brian Hamlin wrote:
>>>>>> Hi Mapfish Team Representatives
>>>>>> it appears that poi_osm data table in postgres failed to load
>>>>>> in the
>>>>>> build process
>>>>>> Please check the logs and/or the virtual machine image
>>>>>> hth
>>>>>> -Brian
>>>>>> Brian Hamlin
>>>>>> planetwork.net
>>>>>> (415) 717-4462 cell
>>>>>> _______________________________________________
>>>>>> Live-demo mailing list
>>>>>> Live-demo at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>>>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
>>>>> Cameron Shorter
>>>>> Geospatial Director
>>>>> Tel: +61 (0)2 8570 5050
>>>>> Mob: +61 (0)419 142 254
>>>>> Think Globally, Fix Locally
>>>>> Geospatial Solutions enhanced with Open Standards and Open Source
>>>>> http://www.lisasoft.com
>>>> Bruno Binet
>>>> Camptocamp France SAS
>>>> Savoie Technolac, BP 352
>>>> 73377 Le Bourget du Lac, Cedex
>>>> Mail : bruno.binet at camptocamp.com
>>>> http://www.camptocamp.com
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
More information about the Live-demo
