[Live-demo] 4.5alpha3 Built - Mapfish
Brian Hamlin maplabs at light42.com
Sun Feb 20 18:27:51 EST 2011
All-
   I have confirmed rev 5697 of install_mapfish runs successfully
Please note that web2py installs in /usr/local/lib/
  it seems that would be a good place to put MapFishSample
  great to see MapFish running on the LiveDVD!
best regards from California
   -Brian
Brian Hamlin
planetwork.net
OSGeo California Chapter
(415) 717-4462 cell
On Feb 20, 2011, at 11:24 AM, Hamish wrote:
> Angelos wrote:
>>>> After trying the Mapfish icon, I get an error that
>>>> the page is not found.
> Hamish:
>>> try editing the icon file:
>>> -Exec=sensible-browser http://localhost/mapfishsample/osgeolive/wsgi/
>>> +Exec=sensible-browser
>>> http://localhost/mapfishsample_2.0/osgeolive/wsgi/
> Bruno:
>> What do you mean? The correct url should be
>> http://localhost/mapfishsample/osgeolive/wsgi/ is I
>> recall correctly.
> I was making an assumption based on this line in
> buildout_osgeolive.cfg:
> [vars]
> apache-entry-point = /mapfishsample_2.0/
>>> some comments, the most important one is the change above, and
>>> 'svn co' vs 'svn export' (I'm on the hunt for disc space).
>> Ok, fixed.
> thanks.
> fwiw, 'svn co' in the /tmp/build_mapfish/ dir is ok, as the
> /tmp/build_* dirs are stripped out of the final ISO, but then
> a 'cp -r' would need to skip internal .svn/ dirs, so maybe export
> is best. I guess 'export' just makes the script being run the
> second time less efficient? but that's a minor concern.
>>> please install to /usr/local/bin:
>>>  INSTALL_DIR="/usr/lib"
>> Why? Mapfish sample application is not an executable.
> I think I sent a followup email, .../bin was a mistake, I meant
> to write /usr/local/lib.
>> I might change install location to /usr/local/lib instead.
>> (I don't update this location until I get a confirmation
>> from you)
> /usr/local/lib is already in /etc/ld.so.conf.d/, but you may
> want to run ldconfig after this step.
>>> epsg:900913 is already stored in /usr/share/proj/esri.extra
>> Ok removed.
> you tested this one, right? :) I'm only pretty-sure it works.
>>> re. other people's troubles, perhaps stop tomcat at
>>> the start of the script,
>>> then start it again at the end instead of just
>>>  /etc/init.d/tomcat6 restart
>>> at the end? (? probably that's really a pgsql error
>>> not a tomcat one but who knows...)
>> Sorry, I don't understand what you mean. What are these
>> troubles with tomcat?
> this:
>> Angelos wrote:
>>> I just did an update on the vm as Cameron suggested and
>>> Mapfish does not start.
>>> The script log shows an error about not being able to
>>> update some db table, being accessed by other users.
> cheers, it's looking good!
> Hamish
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo mailing list
