[Live-demo] 4.5alpha3 Built - Mapfish
Cameron Shorter cameron.shorter at gmail.com
Sun Feb 20 18:34:32 EST 2011
Bruno,
Which version of MapFish should we be reporting as being installed on
OSGeo-Live?
Does rev 5697 equate to version 2.0?
On 21/02/2011 10:27 AM, Brian Hamlin wrote:
> All-
>   I have confirmed rev 5697 of install_mapfish runs successfully
> Please note that web2py installs in /usr/local/lib/
>  it seems that would be a good place to put MapFishSample
>  great to see MapFish running on the LiveDVD!
> best regards from California
>   -Brian
> Brian Hamlin
> planetwork.net
> OSGeo California Chapter
> (415) 717-4462 cell
> On Feb 20, 2011, at 11:24 AM, Hamish wrote:
>> Angelos wrote:
>>>>> After trying the Mapfish icon, I get an error that
>>>>> the page is not found.
>> Hamish:
>>>> try editing the icon file:
>>>> -Exec=sensible-browser http://localhost/mapfishsample/osgeolive/wsgi/
>>>> +Exec=sensible-browser
>>>> http://localhost/mapfishsample_2.0/osgeolive/wsgi/
>> Bruno:
>>> What do you mean? The correct url should be
>>> http://localhost/mapfishsample/osgeolive/wsgi/ is I
>>> recall correctly.
>> I was making an assumption based on this line in buildout_osgeolive.cfg:
>> [vars]
>> apache-entry-point = /mapfishsample_2.0/
>>>> some comments, the most important one is the change above, and
>>>> 'svn co' vs 'svn export' (I'm on the hunt for disc space).
>>> Ok, fixed.
>> thanks.
>> fwiw, 'svn co' in the /tmp/build_mapfish/ dir is ok, as the
>> /tmp/build_* dirs are stripped out of the final ISO, but then
>> a 'cp -r' would need to skip internal .svn/ dirs, so maybe export
>> is best. I guess 'export' just makes the script being run the
>> second time less efficient? but that's a minor concern.
>>>> please install to /usr/local/bin:
>>>>  INSTALL_DIR="/usr/lib"
>>> Why? Mapfish sample application is not an executable.
>> I think I sent a followup email, .../bin was a mistake, I meant
>> to write /usr/local/lib.
>>> I might change install location to /usr/local/lib instead.
>>> (I don't update this location until I get a confirmation
>>> from you)
>> /usr/local/lib is already in /etc/ld.so.conf.d/, but you may
>> want to run ldconfig after this step.
>>>> epsg:900913 is already stored in /usr/share/proj/esri.extra
>>> Ok removed.
>> you tested this one, right? :) I'm only pretty-sure it works.
>>>> re. other people's troubles, perhaps stop tomcat at
>>>> the start of the script,
>>>> then start it again at the end instead of just
>>>>  /etc/init.d/tomcat6 restart
>>>> at the end? (? probably that's really a pgsql error
>>>> not a tomcat one but who knows...)
>>> Sorry, I don't understand what you mean. What are these
>>> troubles with tomcat?
>> this:
>>> Angelos wrote:
>>>> I just did an update on the vm as Cameron suggested and
>>>> Mapfish does not start.
>>>> The script log shows an error about not being able to
>>>> update some db table, being accessed by other users.
>> cheers, it's looking good!
>> Hamish
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
