[Live-demo] OSGeo-Live 4.5 - OSGEarth
Cameron Shorter
cameron.shorter at gmail.com
Sun Feb 27 23:58:58 EST 2011
On 28/02/11 14:29, Hamish wrote:
> Cameron wrote:
>> It might be the case that OSGEarth doesn't work without
>> OpenGL support. If that is the case, is it possible to fail
>> gracefully? Eg: In a wrapper bash script test for the
>> existence of OpenGL. If it doesn't exist, present up popup
>> alert stating "This computer seems to be missing OpenGL
>> support is required to fully make use of OGLEarth. Elements
>> of this program will not work as expected."
> Virtual Machines + OpenGL are a know problem (bug) industry wide. AFAIK
> we've done all we can and are installing everything needed, and if the
> ISO is burnt onto a physical DVD or USB stick and booted from that then
> everything works correctly.
> not much we can do about it. hopefully a newer version of VirtualBox or
> whatever makes this better.
> Hamish
I expect that a significant proportion of our users will test OSGeo-Live
from a Virtual Machine. (I guess 20% to 30%). Maybe we should test to
see if the application is being run inside a VM, and provide a popup
warning if so. Is it possible to test if you are running in a VM?
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo
