[Live-demo] OSGeo-Live 4.5 - OSGEarth
    Brian Hamlin
    maplabs at light42.com
    Mon Feb 28 00:13:55 EST 2011
On Feb 27, 2011, at 8:58 PM, Cameron Shorter wrote:
> On 28/02/11 14:29, Hamish wrote:
>> Cameron wrote:
>>> It might be the case that OSGEarth doesn't work without
>>> OpenGL support. If that is the case, is it possible to fail
>>> gracefully? Eg: In a wrapper bash script test for the
>>> existence of OpenGL. If it doesn't exist, present up popup
>>> alert stating "This computer seems to be missing OpenGL
>>> support is required to fully make use of OGLEarth. Elements
>>> of this program will not work as expected."
>> Virtual Machines + OpenGL are a know problem (bug) industry wide.
>> AFAIK
>> we've done all we can and are installing everything needed, and if the
>> ISO is burnt onto a physical DVD or USB stick and booted from that
>> then
>> everything works correctly.
>> not much we can do about it. hopefully a newer version of VirtualBox
>> or
>> whatever makes this better.
>> Hamish
> I expect that a significant proportion of our users will test
> OSGeo-Live from a Virtual Machine. (I guess 20% to 30%). Maybe we
> should test to see if the application is being run inside a VM, and
> provide a popup warning if so. Is it possible to test if you are
> running in a VM?
Here in the Bay Area, next to Silicon Valley, I would expect that
number to be closer to 100%
Is it up to the LiveDVD to handle the Virtual Machine case?
   -Brian
> Cameron Shorter
> Geospatial Solutions Manager
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo
