[Live-demo] Re: Which version of ossim should be installed on the
next OSGeo-Live?
Massimo Di Stefano
massimodisasha at gmail.com
Mon Jul 4 07:33:39 EDT 2011
Hi All
finally back at home i had a chance to update the ossim build to the latest svn on Xubunu 11.04
i tried the script and "maybe" should works ... the only issue is about the desktop icons
they use the old path :
/usr/local/ossim/executable
instead of :
/usr/local/ossim/bin/executable
where are stored the .desktop files on the svn repository?
i'll apply this changes and i'll try the script on a fresh VM to test it.
thanks.
Massimo.
Il giorno 26/giu/2011, alle ore 15.16, cameron.shorter at gmail.com ha scritto:
> Pirmin, Massimo,
> Did you notice Hamish's analysis of OSGeo-Live build logs. Could you please have a look at his comments about: ossim. If you have questions, I'm sure Hamish will be happy to expand.
> On 26/06/11 14:55, Hamish wrote:
>> Alex wrote:
>>> http://live.osgeo.org/dev/build/5alpha2-log.tar.gz
>>> Went a little better than last time. I had to manually
>>> interrupt and restart it (though not clean) somewhere towards
>>> the end of Java stuff.
>> thanks,
>>> Opps sorry I didn't up the version on the alpha build (I
>>> always forget that each new cycle).
>> semi-bumped now. a build-checklist.txt in svn might help ..
>>> If the logs look decent after a day I'll go ahead and pack
>>> a vm for people to download to make future testing of scripts
>>> easier on the 5.0 version.
>> still propagating packaging errors in this one leaving the
>> system in a broken state...
>> 5.0a2 quick build log review:
>> everyone:
>> ${CURLY} brackets do nothing to protect the command line from
>> spaces and special chars within variables. Use "double quotes"
>> for that.
>> geoserver:
>> FIXME: 'export FOO=bar' is a Bashism and will not work with Ubuntu's #!/bin/sh (which is dash)
>> geomajas:
>> GeoMajas FIXME: Do not use 777 if at all possible.
>> geonetwork:
>> any way to make your 250mb package smaller?
>> deegree, openjump, maptiler:
>> FIXME: don't use wget for local files, just copy from local svn checkout: cp ../app-conf/$FILE $DEST
>> gvSIG:
>>> mv: cannot stat `gvSIG19_new_features.tar.gz': No such file or directory
>> etc.
>> osm:
>> temporary DNS trouble, now fixed?
>> Static copy of Denver.osm.bz2 now stashed on OSGeo download server, note
>> many times bigger than Barcelona, which may make the PostGIS DB
>> huge?
>> Sahaha:
>> a number of errors, e.g.:
>>> DataError: value too long for type character varying(64)
>>> OSError: [Errno 13] Permission denied: 'applications/eden/compiled'
>> Ushahidi:
>>> ... Ushahidi already downloaded
>>> tar: A lone zero block at 17095
>> (probably want to do a timestamp check with the wget, but -N and -O are
>> mutually exclusive)
>>> ERROR 1045 (28000): Access denied for user 'root'@'localhost'
>> there is no root password. try operating as another user name.
>> geopublisher, atlasstyler:
>>> E: Package 'geopublishing-doc' has no installation candidate
>> mapfish:
>>> Download error: [Errno -2] Name or service not known -- Some packages may not be found!
>> script is very verbose, making it hard to pick out real error
>> messages.
>> mapguide:
>> .debs need to be updated for Ubuntu 11.04, ie to not depend on odbcinst1debian1
>> Uses a disproportionate amount of disc space (>375mb). please
>> find ways to slim it down.
>> [after this all other deb installs are broken for the rest of the ISO build..]
>> ossim:
>> wants libgdal1-1.7.0, but only 1.6.0 and 1.8.0 are available.
>> -> rebuild for natty
>> WARNING: wget -N timestamping does nothing in combination with -O.
>> 52nSOS:
>> please shut off pgsql verbose mode & fix errors, if possible.
>> otb:
>> fails-- no packages for ubuntu/natty found in PPA.
>> [after this even less of the apt system works...]
>> disc space:
>> can we safely uninstall linux-headers-2.6.38-8? (81.5mb)
>> + linux-headers-2.6.38-8-generic (10mb)
>> (is building the proprietary nvidia driver a critical need?)
>> Hamish
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
> Cameron Shorter
> Geospatial Director
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
More information about the Live-demo
