[Live-demo] Re: Which version of ossim should be installed on the next OSGeo-Live?
Massimo Di Stefano massimodisasha at gmail.com
Mon Jul 4 07:57:46 EDT 2011
i fixed the .desktop files .. they was in the ossim_setting.tar.gz package
now should be ok.
Il giorno 04/lug/2011, alle ore 13.33, Massimo Di Stefano ha scritto:
> Hi All
> finally back at home i had a chance to update the ossim build to the latest svn on Xubunu 11.04
> i tried the script and "maybe" should works ... the only issue is about the desktop icons
> they use the old path :
> /usr/local/ossim/executable
> instead of :
> /usr/local/ossim/bin/executable
> where are stored the .desktop files on the svn repository?
> i'll apply this changes and i'll try the script on a fresh VM to test it.
> thanks.
> Massimo.
> Il giorno 26/giu/2011, alle ore 15.16, cameron.shorter at gmail.com ha scritto:
>> Pirmin, Massimo,
>> Did you notice Hamish's analysis of OSGeo-Live build logs. Could you please have a look at his comments about:  ossim. If you have questions, I'm sure Hamish will be happy to expand.
>> On 26/06/11 14:55, Hamish wrote:
>>> Alex wrote:
>>>> http://live.osgeo.org/dev/build/5alpha2-log.tar.gz
>>>> Went a little better than last time. I had to manually
>>>> interrupt and restart it (though not clean) somewhere towards
>>>> the end of Java stuff.
>>> thanks,
>>>> Opps sorry I didn't up the version on the alpha build (I
>>>> always forget that each new cycle).
>>> semi-bumped now. a build-checklist.txt in svn might help ..
>>>> If the logs look decent after a day I'll go ahead and pack
>>>> a vm for people to download to make future testing of scripts
>>>> easier on the 5.0 version.
>>> still propagating packaging errors in this one leaving the
>>> system in a broken state...
>>> 5.0a2 quick build log review:
>>> everyone:
>>> ${CURLY} brackets do nothing to protect the command line from
>>> spaces and special chars within variables. Use "double quotes"
>>> for that.
>>> geoserver:
>>> FIXME: 'export FOO=bar' is a Bashism and will not work with Ubuntu's #!/bin/sh  (which is dash)
>>> geomajas:
>>> GeoMajas FIXME: Do not use 777 if at all possible.
>>> geonetwork:
>>> any way to make your 250mb package smaller?
>>> deegree, openjump, maptiler:
>>> FIXME: don't use wget for local files, just copy from local svn checkout:  cp ../app-conf/$FILE $DEST
>>> gvSIG:
>>>> mv: cannot stat `gvSIG19_new_features.tar.gz': No such file or directory
>>> etc.
>>> osm:
>>> temporary DNS trouble, now fixed?
>>> Static copy of Denver.osm.bz2 now stashed on OSGeo download server, note
>>> many times bigger than Barcelona, which may make the PostGIS DB
>>> huge?
>>> Sahaha:
>>> a number of errors, e.g.:
>>>> DataError: value too long for type character varying(64)
>>>> OSError: [Errno 13] Permission denied: 'applications/eden/compiled'
>>> Ushahidi:
>>>> ... Ushahidi already downloaded
>>>> tar: A lone zero block at 17095
>>> (probably want to do a timestamp check with the wget, but -N and -O are
>>> mutually exclusive)
>>>> ERROR 1045 (28000): Access denied for user 'root'@'localhost'
>>> there is no root password. try operating as another user name.
>>> geopublisher, atlasstyler:
>>>> E: Package 'geopublishing-doc' has no installation candidate
>>> mapfish:
>>>> Download error: [Errno -2] Name or service not known -- Some packages may not be found!
>>> script is very verbose, making it hard to pick out real error
>>> messages.
>>> mapguide:
>>> .debs need to be updated for Ubuntu 11.04, ie to not depend on odbcinst1debian1
>>> Uses a disproportionate amount of disc space (>375mb). please
>>> find ways to slim it down.
>>> [after this all other deb installs are broken for the rest of the ISO build..]
>>> ossim:
>>> wants libgdal1-1.7.0, but only 1.6.0 and 1.8.0 are available.
>>> -> rebuild for natty
>>> WARNING: wget -N timestamping does nothing in combination with -O.
>>> 52nSOS:
>>> please shut off pgsql verbose mode & fix errors, if possible.
>>> otb:
>>> fails-- no packages for ubuntu/natty found in PPA.
>>> [after this even less of the apt system works...]
>>> disc space:
>>> can we safely uninstall linux-headers-2.6.38-8? (81.5mb)
>>> + linux-headers-2.6.38-8-generic (10mb)
>>> (is building the proprietary nvidia driver a critical need?)
>>> Hamish
>>> Live-demo mailing list
>>> Live-demo at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
>> Cameron Shorter
>> Geospatial Director
>> Tel: +61 (0)2 8570 5050
>> Mob: +61 (0)419 142 254
>> Think Globally, Fix Locally
>> Geospatial Solutions enhanced with Open Standards and Open Source
>> http://www.lisasoft.com
More information about the Live-demo mailing list
