[Live-demo] Enhancement for Version number in Online Documentation
Alex Mandel
tech_dev at wildintellect.com
Thu Jul 7 13:21:10 EDT 2011
Frank,
No there is not a deployment script which uploads the ISOs, it's much
more complicated than you think since that url is actually redirected to
a tool that then sorts people's downloads amongst the 5 mirrors.
The url as defined by the last release will be correct for the next release.
Where:
http://download.osgeo.org/livedvd/release/[version]/osgeo-live-[version].iso
http://download.osgeo.org/livedvd/release/[version]/osgeo-live-mini-[version].iso
http://download.osgeo.org/livedvd/release/[version]/osgeo-live-vm-[version].7z
End up as:
http://download.osgeo.org/livedvd/release/5.0/osgeo-live-5.0.iso
I'll just have to remember to stick to that naming convention when I'm
making new versions.
Thanks,
Alex
On 07/07/2011 06:24 AM, Frank Gasdorf wrote:
> All right, Sorry for the confusion ...
> I've updated to index, download and overview pages. What I've done:
> added rst_epilog to the conf.py script and replaced at the specific places
> OSGeo-Live with |osgeo-live-version| which is a concatenation of the project
> and the projects version:
> .. |osgeo-live-version| replace:: %(projectname)s %(projectversion)s
> in addition I defined a replacement |osgeo-live-project| which can be used
> everywhere OSGeo-Live is currently in the docs ...
> Could please somebody *review *the *Japanese *index page.
> What's next:
> We should update the URL's in download pages and make these dynamic by using
> the version number as well. I've no idea where the path would be correct if
> we would replace (see |version|:
> e.g:
> http://download.osgeo.org/livedvd/release/4.5/osgeo-live-4.5.iso
> with
> http://download.osgeo.org/livedvd/release/|version|/osgeo-live-|version|.iso
> is there a deployment script which uploads the ISO files? Where can I find
> it?
> Cheers, Frank
> 2011/7/7 Cameron Shorter <cameron.shorter at gmail.com>
>> On 07/07/11 20:10, Frank Gasdorf wrote:
>> Right, I removed the version from makefile, because it's a post process on
>> html files and have not replaced all OSGeo Live occurrences. Few days ago I
>> requested an enhancement to put the version number at a specific place, lets
>> say right behind the banner, that every page shows the current version
>> number. I haven't got any feedback yet. IMHO the whole doc should be without
>> any version number, except the HOME index page.
>> I suggest you go ahead and insert the version tag in:
>> http://live.osgeo.org/en/index.html
>> Welcome to OSGeo-Live <version>
>> http://live.osgeo.org/en/overview/overview.html
>> OSGeo-Live <version> Contents
>> http://live.osgeo.org/en/download.html
>> The latest stable release of OSGeo-Live <version>:
>> Whats next? I'll go over and replace all OSGeo-Live places with
>> OSGeo-Live |version| and thats it. Otherwise we could use replacements, but
>> right now I don't know how to define global values, that can be referenced
>> in all *.rst files.
>> If you are not able to work out how to insert the global variables, then we
>> should revert to using the previous post HTML production of inserting
>> VERSION. It is not perfect, but it does work.
>> Thanks a lot for the adhoc url, that everybody can have a look at the
>> current content! Are the pages uploaded daily?
>> Yes, reloaded daily.
>> Cheers, Frank
>>> Frank,
>>> Checking the latest changes to the Makefile, it seems we have lost the
>>> VERSION from the documents.
>>> You can see a link to a nightly build here:
>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc#Documentation
>>> to
>>> http://adhoc.osgeo.osuosl.org/livedvd/docs/en/index.html
>>> Are you able to look into this?
>>> We don't have a nightly mavin build or similar automated build process
>>> (yet). Having one could make our build process easier if someone were able
>>> to set it up.
>>> On 04/07/11 17:02, Frank Gasdorf wrote:
>>> Thanks Hamish, please have a look at the inline comments ..
>>> 2011/7/4 Hamish <hamish_b at yahoo.com>
>>>> Frank wrote:
>>>>> OK, just fixed the version read from VERSION.txt in conf.py
>>>>> and updated html_tilte property - in the title was still v4.5
>>>>> instead of the current version.
>>>> thanks
>>>>> I tried it on mac os but the arguments for sphinx-build
>>>>> command where not used like I thought it would. Therefore the
>>>>> python conf.py update to read from version file instead of
>>>>> parameters for sphinx-build command in Makefile
>>>> sphinx has been a bit of a moving target.. can you set up a
>>>> virtual machine in OSX to run xubuntu 11.04 in? it's the best
>>>> way to verify the results are the same.
>>> Agree, it was only mentioned to get feedback if anybody else had
>>> problems like this. I know, that the geotools project works with ant build
>>> scripts and there it seems to work but I've no idea what OS the build server
>>> for the docs is running.
>>>> also note that if the Makefile changes the nightly doc build
>>>> on the adhoc server stops until I validate them. (intentional
>>>> feature, not a bug)
>>>> Quit interesting. Everything still all right after my changes? Is there
>>> a public accessible build server (hudson/jenkins) where I can check the
>>> build results? Is it possible to get these results to the mailing list?
>>>>> In addition I searched all 'OSGeo Live' occurrences and
>>>>> replaced it with OSGeo-Live.
>>>> it would be better to make the grep regex more robust, rather
>>>> than forcing all docs to use an identical version of the nom du
>>>> jour.
>>>> grep 'OSGeo[ -]Live' *.rst
>>>> Thanks! To be exact I used the sed and searched the regular expression
>>> 'OSGeo.Live' and replaced it with OSGeo-Live. ;)
>>>>> Last but not least I updated the copyright to 2011.
>>>> thanks,
>>>> with respect to :Version: in the ReST docs header comments, I
>>>> would like to preserve that, it makes it easy to know if I've
>>>> verified that the content is still valid for the currently
>>>> packaged version of the software. (making it the version of
>>>> the software would be just as good) that version doesn't need
>>>> to be exported beyond the ReST document though.
>>>> cheers,
>>>> Hamish
More information about the Live-demo
