[Live-demo] Please help keep MapGuide on LiveDVD 5.0
Cameron Shorter
cameron.shorter at gmail.com
Mon Jul 11 15:47:58 EDT 2011
The Mapguide team haven't had the time to migrate their build process
over Ubuntu 11.04 (used by the next OSGeo-Live) and will need help if
they are going to keep MapGuide on the DVD.
This would be disappointing, as MapGuide would be the only incubated
project not included. If there are any techies with some familiarity
resolving c based build issues who can help out, I'd be keen to hear
from you.
Trevor has provided some details below, and I assume would be available
to answer questions from anyone who is helping out.
On 12/07/11 04:27, Trevor Wekel wrote:
> Hi Cameron,
> If the developer has Linux experience, they may be able to work through it. There are some build guides for FDO and MapGuide already posted for previous releases. They may be "close" for the current sources.
> http://svn.osgeo.org/fdo/trunk/CMake__README.txt
> http://trac.osgeo.org/mapguide/wiki/CompilingMapGuide22
> http://trac.osgeo.org/mapguide/wiki/CompilingMapGuide22Centos54
> Compiling against trunk brings in "newer" third party dependencies which should be compatible with gcc 4.4.
> I started working through the FDO build on Ubuntu 10. Ubuntu 11 should be similar. If Ubuntu 11 has a newer Xalan, the build Xalan from source step below could be dropped. Please note, these build steps are incomplete.
> Install compilation environment
> apt-get install gcc g++ autoconf automake automake1.7 libtool bison
> apt-get install zlib1g zlib1g-dev zlibc libjpeg-dev libxml2-dev
> apt-get install subversion
> apt-get install perl
> Compile using Cmake
> apt-get install cmake libgdal-dev libcppunit-dev libxerces-c3-dev python-dev
> apt-get install libboost-dev
> apt-get install libcurl4-openssl-dev
> Build xalan from Thirdparty source
> cd Thirdparty/apache/xalan
> export XALANCROOT=/root/fdo36/Thirdparty/apache/xalan
> ./runConfigure -p linux -c gcc -x g++
> make
> make install
> mkdir cmakedir
> cd cmakedir
> cmake ../fdo36 -DINTERNAL_GDAL=TRUE
> make
> I have one patch for FDO the build (below). Others may be required.
> Index: Fdo/Unmanaged/Src/CMakeLists.txt
> --- Fdo/Unmanaged/Src/CMakeLists.txt (revision 6167)
> +++ Fdo/Unmanaged/Src/CMakeLists.txt (working copy)
> @@ -225,6 +225,7 @@
> Common/Xsl/XML885915Transcoder.cpp
> Common/Gml212/Schema.cpp
> Common/Gml212/Gml212.cpp
> + Common/Gml311/Gml311.cpp
> Regards,
> Trevor
Cameron Shorter
Geospatial Director
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo
