[Live-demo] Please help keep MapGuide on LiveDVD 5.0
Johan Van de Wauw johan.vandewauw at gmail.com
Fri Jul 15 04:47:56 EDT 2011
I have a bit of spare time next week, and I may try to help out - but
I'm not guaranteeing anything. I'll first make sure that saga and
mapserver are up to date on the live dvd.
Perhaps we should set up a repository with all changes necessary to
build on ubuntu 11.04? I prefer git - but can sync that with others.
Apart from that: I first want to be sure that my changes will actually
be considered for inclusion in the later mapguide releases. I don't
want to spend my little spare time packaging this thing only for the
live dvd.
Johan
On Mon, Jul 11, 2011 at 9:47 PM, Cameron Shorter
<cameron.shorter at gmail.com> wrote:
> The Mapguide team haven't had the time to migrate their build process over
> Ubuntu 11.04 (used by the next OSGeo-Live) and will need help if they are
> going to keep MapGuide on the DVD.
> This would be disappointing, as MapGuide would be the only incubated project
> not included. If there are any techies with some familiarity resolving c
> based build issues who can help out, I'd be keen to hear from you.
> Trevor has provided some details below, and I assume would be available to
> answer questions from anyone who is helping out.
> On 12/07/11 04:27, Trevor Wekel wrote:
>> Hi Cameron,
>> If the developer has Linux experience, they may be able to work through
>> it.  There are some build guides for FDO and MapGuide already posted for
>> previous releases.  They may be "close" for the current sources.
>> http://svn.osgeo.org/fdo/trunk/CMake__README.txt
>> http://trac.osgeo.org/mapguide/wiki/CompilingMapGuide22
>> http://trac.osgeo.org/mapguide/wiki/CompilingMapGuide22Centos54
>> Compiling against trunk brings in "newer" third party dependencies which
>> should be compatible with gcc 4.4.
>> I started working through the FDO build on Ubuntu 10.  Ubuntu 11 should be
>> similar.  If Ubuntu 11 has a newer Xalan, the build Xalan from source step
>> below could be dropped.  Please note, these build steps are incomplete.
>> Install compilation environment
>> apt-get install gcc g++ autoconf automake automake1.7 libtool bison
>> apt-get install zlib1g zlib1g-dev zlibc libjpeg-dev libxml2-dev
>> apt-get install subversion
>> apt-get install perl
>> Compile using Cmake
>> apt-get install cmake libgdal-dev libcppunit-dev libxerces-c3-dev
>> python-dev
>> apt-get install libboost-dev
>> apt-get install libcurl4-openssl-dev
>> Build xalan from Thirdparty source
>> cd Thirdparty/apache/xalan
>> export XALANCROOT=/root/fdo36/Thirdparty/apache/xalan
>> ./runConfigure -p linux -c gcc -x g++
>> make
>> make install
>> mkdir cmakedir
>> cd cmakedir
>> cmake ../fdo36 -DINTERNAL_GDAL=TRUE
>> make
>> I have one patch for FDO the build (below).  Others may be required.
>> Index: Fdo/Unmanaged/Src/CMakeLists.txt
>> --- Fdo/Unmanaged/Src/CMakeLists.txt    (revision 6167)
>> +++ Fdo/Unmanaged/Src/CMakeLists.txt    (working copy)
>> @@ -225,6 +225,7 @@
>>         Common/Xsl/XML885915Transcoder.cpp
>>         Common/Gml212/Schema.cpp
>>         Common/Gml212/Gml212.cpp
>> +       Common/Gml311/Gml311.cpp
>> Regards,
>> Trevor
> Cameron Shorter
> Geospatial Director
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo mailing list
