[Live-demo] LiveDVD 4.5b2 - Geomajas 1.8.0
Angelos Tzotsos gcpp.kalxas at gmail.com
Wed Mar 9 08:06:39 EST 2011
I managed to find the issue, it is permissions in the webapps directory.
I will create a fix, test it and let you know about the results.
Regards,
Angelos
On 03/09/2011 02:32 PM, Pieter De Graef wrote:
> Hmm,
> this is a problem. I don't see any errors in the logs. It seems as if
> everything booted correctly. As for the JSP error, thats not an actual
> error, but information from the Jetty container saying that it will
> not support JSP files. This is not a problem since Geomajas does not
> use any JSP files.
> See here: http://wiki.eclipse.org/Jetty/FAQ#JSP_support_not_configured.3F
> So...I'm downloading the LiveDvd right now. I'll try and boot it up
> later (download takes a while).
> I was also thinking... the first time I installed Geomajas on the
> LiveDVD there a simple timing issue that made it seem as if Geomajas
> was not correctly installed. It started FireFox while Geomajas was
> still starting up, and so gave an error message. Have you tried
> waiting a bit longer and than visiting the URL in firefox?
> 2011/3/9 Angelos Tzotsos <gcpp.kalxas at gmail.com
> <mailto:gcpp.kalxas at gmail.com>>
>     Hi Pieter,
>     The problem is on startup. I am sending you the startup log. There
>     is a message about "No JSP support for /showcase".
>     GeoMajas seems to install, there are startup links on the desktop.
>     When we do a build, we start almost from scratch, we just have a
>     preinstalled Xubuntu virtual machine ready with updates.
>     The installation logs are here:
>     http://osprey.ucdavis.edu/downloads/osgeo/gisvm/latest/4.5beta3-log.tar.gz
>     The virtual machine is here:
>     http://osprey.ucdavis.edu/downloads/osgeo/gisvm/latest/OSGeoLive-v4.5beta3.7z
>     or mirrored here:
>     http://aiolos.survey.ntua.gr/gisvm/dev/OSGeoLive-v4.5beta3.7z
>     Thanks for your help,
>     Regards,
>     Angelos
>     On 03/09/2011 09:30 AM, Pieter De Graef wrote:
>>     I'm sorry I haven't been in touch the last couple of days. I've
>>     been working behind a pretty secure firewall, and can't event SSH
>>     to the outside world...
>>     Where exactly does it go wrong? Is Geomajas downloaded
>>     successfully? Is it a problem during startup?
>>     If it is a problem during startup, could you send me the Tomcat logs?
>>     Also, when you guys do a build, do you always start from scratch?
>>     I noticed that in the install script it checks whether or not
>>     Geomajas has already been downloaded, but I recently had to make
>>     a change to the download package, so perhaps the new one wasn't
>>     used...
>>     PS: Is there still that virtualbox url somewhere so I can see for
>>     myself?
>>         Hi Peter,
>>         It seems that GeoMajas does not work in version 4.5 beta3:
>>         http://trac.osgeo.org/osgeo/ticket/675
>>         Can you please advise?
>>         Regards,
>>         Angelos
>>         On 02/28/2011 01:10 PM, Pieter De Graef wrote:
>>             Update:
>>             There was indeed a problem starting the Jetty web
>>             container. This should be solved now.
>>             On 02/28/2011 08:14 AM, Pieter De Graef wrote:
>>                 Brian,
>>                 I will look into it asap.
>>                 On 02/26/2011 12:04 PM, Brian Hamlin wrote:
>>                     Geomajas Team Representatives -
>>                      testing the build on the latest LiveDVD, I ran
>>                     into a number of permission problems with the
>>                     install, as I understand it..
>>                     Although i checked in several small changes to
>>                     the install script, I still see the following error
>>                      $ /usr/lib/geomajas-1.8.0-bin/bin/startup.sh
>>                      INFO::NO JSP Support for /Showcase, did not find
>>                     org.apache.lasper.servlet.JspServlet
>>                     and an error is shown when browsing to
>>                     localhost:3420/showcase/
>>                      please confirm this as soon as possible, thanks
>>                       -Brian
>>                     Brian Hamlin
>>                     planetwork.net <http://planetwork.net>
>>                     OSGeo California Chapter
>>                     (415) 717-4462 cell
>>                     _______________________________________________
>>                     Live-demo mailing list
>>                     Live-demo at lists.osgeo.org
>>                     <mailto:Live-demo at lists.osgeo.org>
>>                     http://lists.osgeo.org/mailman/listinfo/live-demo
>>                     http://wiki.osgeo.org/wiki/Live_GIS_Disc
>>         Angelos Tzotsos
>>         Remote Sensing Laboratory
>>         National Technical University of Athens
>>         http://users.ntua.gr/tzotsos
>     Angelos Tzotsos
Angelos Tzotsos
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110309/b6904609/attachment.html
More information about the Live-demo mailing list
