[Live-demo] Hot Swapping Datasets
Cameron Shorter
cameron.shorter at gmail.com
Fri Oct 14 15:46:52 EDT 2011
Bob,
I'd love to see such a "localisation" tool created for osgeo-live. If
you have the time and dedication to follow through on it, then go for
it. But be aware that there are close to 50 applications on osgeo-live,
and each of them would likely to be customised in some way to support
the "localisation" feature, and then tested.
Ie, 1 day of simple customisation and testing for one application
becomes 2.5 months when applied to all osgeo-live applications. In
practice, it will likely be one person who will need to take on most of
that 2.5 months of getting the "localisation" feature up and running to
the point that projects continue to maintain it.
On 15/10/2011 6:26 AM, Bob Basques wrote:
> Cameron (and others),
> I'm still thinking this is worth the effort at some point. The easier
> the process is to make a local datseta available inside of the apps,
> the (VERY much) more likely, the app will come off in good standing
> with the testers.
> Is this possibly a separate tool that I'm talking about, that could be
> used after the fact on the LiveDVD? With the sample data all tweaked
> to similar locations and by adding a Data installer script . . .
> bobb
> >>> Cameron Shorter <cameron.shorter at gmail.com> wrote:
> Bob,
> I'm very wary of anything to do with hot-swapping datasets.
> One of the main pillar stones of OSGeo-Live is quality, which is
> achieved by systematic testing, re-testing, then testing again, year
> after year. We now have years and years of testing of applications
> behind us.
> Hot swapping a base dataset invalidates the testing for all
> applications which use that dataset, and consequently is highly likely
> to introduce errors - something we are strong wishing to avoid.
> Yes, I agree that it is really nice to make use of a local dataset,
> and someone may wish to do so for one specific example for one
> specific application, which you test yourself. But I strongly urge you
> not to change a dataset for all applications as you either compromise
> the quality of OSGeo-Live, or you are up for many man months worth of
> testing and issue resolution.
> On 15/10/2011 1:14 AM, Bob Basques wrote:
>> All,
>> Related to this thread (I think) . . . .
>> in a future version of the Live DVD, could the installation of apps
>> be setup in a way that allows for swapping out the sample data sets
>> installed across all apps via a single variable or folder storage
>> location in some way. Being able to change the projection would be
>> the next most obvious improvement to something like this as well.
>> You still want to have sample data, but being able to swap this out
>> for localized data for training aspects would be a pretty slick
>> option to provide.
>> Does it make any sense to try and hard applications together based on
>> data, or are the intended app uses to far ranging and require certain
>> types of particular data ?
>> Just a thought.
>> bobb
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://live.osgeo.org
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
> Cameron Shorter
> Geospatial Solutions Manager
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
Cameron Shorter
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20111015/bd2318ae/attachment.html
More information about the Live-demo
