[Live-demo] updating trunk to xubuntu 12.04
Angelos Tzotsos gcpp.kalxas at gmail.com
Sun Apr 29 06:38:24 EDT 2012
Hi Massimo,
Thanks for the info on ossim. It would be preferable to have this fixed
upstream.
About the vbox issue: no I am not getting the same problem. Have you
installed the additions yourself or did you use the ubuntu proposed driver?
Angelos
On 04/29/2012 07:30 AM, Massimo Di Stefano wrote:
> the ossim stuff will not works on 12.04 using the default osg 3.x
> the dev need to adapt the code to run with osg 3.x (ossim is stuck on 2.8)
> … an hack for me will be to build osg2.8 and store only the needed lib the binary pkg … but this will increase the pkg size.
>   i mailed the ossim list to worn them about this.
> Massimo.
> i've a runing vm 12.04 to test the live build too. (it gives me problem with the vbox additions, the mouse pointer has a bad offset .. anyone with the same problem ?  )
> Il giorno Apr 28, 2012, alle ore 10:48 PM, Angelos Tzotsos ha scritto:
>> On 04/29/2012 03:47 AM, Angelos Tzotsos wrote:
>>> On 04/29/2012 02:09 AM, Angelos Tzotsos wrote:
>>>> On 04/29/2012 01:40 AM, Hamish wrote:
>>>>> Hamish wrote:
>>>>>>> everyone ready to update trunk to xubuntu 12.04?
>>>>>>> better that we wait on projects rather than projects wait on
>>>>>>> us.
>>>>> Alex:
>>>>>> Biggest delay right now is that Ubuntugis isn't up to
>>>>>> Precise yet.
>>>>> the wheels are now in motion. they'll catch up.
>>>>> Angelos:
>>>>>>     From what I see, until we have precise target in ubuntugis
>>>>>> repository, we can only test installation on packages that
>>>>>> are not included there...
>>>>> yup, but there are a bunch of those.
>>>>> (and fwiw contributing projects need to vet their own scripts,
>>>>> &   not wait for us to tell them that they're broken)
>>>>> Hamish
>>>>> _______________________________________________
>>>>> Live-demo mailing list
>>>>> Live-demo at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>>>> http://live.osgeo.org
>>>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
>>>> I am testing the install_mysql script and I see there is no mysql-admin package.
>>>> I am commenting it out for now...
>>> Until now I have reviewed:
>>> setup.sh
>>> install_services.sh
>>> install_mysql.sh
>>> install_java.sh
>>> install_apache2.sh
>>> install_tomkat6.sh
>>> For Java, I added the default JDK for ubuntu 12.04 which is default-jdk == openjdk-6-jdk
>>> Is there a reason we want openjdk-7 apart from being a newer version? Why version 6 is still the default in ubuntu?
>>> Thoughts?
>>> Angelos
>> More updates:
>> install_geoserver.sh
>> install_geomajas.sh
>> install_geonetwork.sh
>> install_pycsw.sh
>> All the above scripts work ok.
>> Also tested deegree installation and it works but there is an issue stopping the service. I think this will be fixed since there is a new stable version of deegree to use for 6.0.
>> Angelos
>> Angelos Tzotsos
>> Remote Sensing Laboratory
>> National Technical University of Athens
>> http://users.ntua.gr/tzotsos
Angelos Tzotsos
More information about the Live-demo mailing list
