[Live-demo] Converting docs to UTF encoding
Frank Gasdorf
fgdrf at users.sourceforge.net
Sun Aug 5 14:26:46 PDT 2012
Alex, thanks for sharing this hint!! In the past we had several issues
with other languages as well (es, el, etc). Properly we should think
about a sphinx page "Creating OSGeo-Live Docs with sphinx" with DO's
and DON'Ts for such cases.
In this case I use notepad++ on windows or EncodingMaster on Mac OS X
to convert between encodings afterwards. I absolutely agree with you,
the Documentation Guilde should have your hint, independent from the
doc language your are working on to choose UTF-8 File-Encoding because
sphinx has set utf-8 to default source encoding
(http://sphinx.pocoo.org/rest.html#source-encoding)
What do you think about a documentation_guide.rst file in doc folder
of svn source checkout, where we could just have templates in how to
define headers, how to deal with directives and references. A pretty
good example to start from is the geoserver sphinx guide
(http://docs.geoserver.org/trunk/en/docguide/sphinx.html).
possible guide structure:
- general sphinx syntax
- how to create pages
- quickstart_template
- overview_template
- (standard_template)
- How to start with tranlations
(e.g. How to start translating files (copy paste, encodings, etc)
- References
- sphinx documentations
Opinions?
Cheers,
Frank
2012/8/5 Alex Mandel <tech_dev at wildintellect.com>:
> So one issue we ran into translating Asian languages, when you do an svn
> copy (or a cp) of the English and then start to change the text the file
> is still encoding as Latin. Which appears fine to the end user but ends
> up with ????? in the sphinx builds.
> The workaround we found is to open a blank file, choose utf8 without BOM
> as the encoding, copy and paste the text from the original and then save
> over the original. Note- Using Notepad++ on Windows for this.
> There must be a better way.
> Thanks,
> Alex
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo
