[Live-demo] Converting docs to UTF encoding
Cameron Shorter cameron.shorter at gmail.com
Sun Aug 5 14:30:10 PDT 2012
Frank, good idea,
The place to capture this information is on this wiki page:
http://wiki.osgeo.org/wiki/Live_GIS_Translate
On 06/08/12 07:26, Frank Gasdorf wrote:
> Alex, thanks for sharing this hint!! In the past we had several issues
> with other languages as well (es, el, etc). Properly we should think
> about a sphinx page "Creating OSGeo-Live Docs with sphinx" with DO's
> and DON'Ts for such cases.
> In this case I use notepad++ on windows or EncodingMaster on Mac OS X
> to convert between encodings afterwards. I absolutely agree with you,
> the Documentation Guilde should have your hint, independent from the
> doc language your are working on to choose UTF-8 File-Encoding because
> sphinx has set utf-8 to default source encoding
> (http://sphinx.pocoo.org/rest.html#source-encoding)
> What do you think about a documentation_guide.rst file in doc folder
> of svn source checkout, where we could just have templates in how to
> define headers, how to deal with directives and references. A pretty
> good example to start from is the geoserver sphinx guide
> (http://docs.geoserver.org/trunk/en/docguide/sphinx.html).
> possible  guide structure:
> - general sphinx syntax
> - how to create pages
>      - quickstart_template
>      - overview_template
>      - (standard_template)
> - How to start with tranlations
>   (e.g. How to start translating files (copy paste, encodings, etc)
> - References
>    - sphinx documentations
> Opinions?
> Cheers,
> Frank
> 2012/8/5 Alex Mandel <tech_dev at wildintellect.com>:
>> So one issue we ran into translating Asian languages, when you do an svn
>> copy (or a cp) of the English and then start to change the text the file
>> is still encoding as Latin. Which appears fine to the end user but ends
>> up with ????? in the sphinx builds.
>> The workaround we found is to open a blank file, choose utf8 without BOM
>> as the encoding, copy and paste the text from the original and then save
>> over the original. Note- Using Notepad++ on Windows for this.
>> There must be a better way.
>> Thanks,
>> Alex
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://live.osgeo.org
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
