[Live-demo] [OSGeo] #1001: Failed to install
OSGeo
trac_osgeo at osgeo.org
Mon Aug 27 11:58:52 PDT 2012
Reporter: Aborrell | Owner: live-demo@…
Type: defect | Status: new
Priority: major | Milestone: OSGeoLive6.0Final
Component: LiveDVD | Keywords: ubiquity, 6.0
Changes (by kalxas):
* keywords: ubiquity => ubiquity, 6.0
* type: task => defect
Comment:
Replying to [ticket:1001 Aborrell]:
> Tried to install the live dvd osgeo 6.0 (md5 chacked), both from dvd and
from an usb image. After selecting the language, there is a crash
reporting an error from /usr/lib/ubiquity/bin/ubiquity. and then closes
the application.
> I've tried several machines, several languages with no success. The
systems had other operating systems installed on it, but I tried with an
empty hard disk with no luck. Yet it worked with version 5.5
Hi Aborrell,
Did you use the mini or the full iso? Which language did you try to
install? Can you send here the partition setup you tried to create?
Installing to an empty hard disk has been tested to work ok so far, can
you provide machine specs on which this error occurred? Did you use the
default partition setup for this test?
Regards,
Angelos
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1001#comment:2>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
