[Live-demo] Postgres Apps - MapFish Sahana Rasdaman
PGRoutingGPSDrive
maplabs at light42.com
Sun Jan 22 16:04:37 EST 2012
Hi All-
for the record, the change in interpreting BYTEA in the OGR driver
is very, very old legacy code
and will likely be eliminated in OGR in the not-so-distant future
thx very much to EvenR for his prompt and accurate insights, as usual
The bottom line is, there is very little in Pg9.x that should be of
trouble to the other
projects..
Brian Hamlin
GeoCal
OSGeo California Chapter
415-717-4462 cell
On Sun, 22 Jan 2012 21:28:57 +0100, Even Rouault
<even.rouault at mines-paris.org> wrote:
Le dimanche 22 janvier 2012 21:16:37, maplabs at light42.com a écrit :
> > Compatability for Postgres 9.1 is in the 90% + range
> > The problem people run into is that since Postgres is a fundemental
> > piece of any stack,
> > it is some work to rebuild the stack to test with a new version...
> > > I would be surprised if there are any compatability problems at all for
> > most all apps
> > other than people hard-coding version numbers and the like
> For the record, there are sometimes changes in some configuration
> parameters from one PG version to another one that have lead to the
> following compatibility fix (for a very marginal use case) in GDAL
> recently :
> http://trac.osgeo.org/gdal/changeset/23651/trunk/gdal/ogr/ogrsf_frmts/pg
> (improved in
> http://trac.osgeo.org/gdal/changeset/23652/trunk/gdal/ogr/ogrsf_frmts/pg to
> not be dependant from the PG version )
> > > -Brian
> > > On Mon, 23 Jan 2012 06:46:57 +1100, Cameron Shorter
> > <cameron.shorter at gmail.com> wrote:
> > Brian,
> > > > Based upon Peter's request, my feeling is that we should revert back
> > > to Postgres 8.4.
> > > Our emphasis on OSGeo-Live is "stability over cutting edge". This is
> > > because we are targeting new users who will be very quickly turned
> > > off if they find a bug, and will generally not be looking to check
> > > out the latest and greatest. (They can always go to a project page
> > > later if they want to find latest features).
> > > Anyone wish to weigh in on this topic before we make a call on which
> > > posgres to use?
> > > > > On 22/01/12 20:55, Peter Baumann wrote:
> > > > Hi Brian,
> > > > > > > sorry, we have not tested rasdaman with PG 9.x yet. Given
> the short
> > > > time remaining and current project pressure we won't be able to do
> > > > > so > for this DVD roll-out. As in the past even minor release changes
> > > in PG > have led to incompatibilities this deserves special
> > > attention. We'd > kindly ask you therefore to keep 8.4 available.
> > > > > > thanks for your understanding,
> > > > Peter
> > > > > > > On 01/22/2012 06:15 AM, maplabs at light42.com wrote:
> > > >> Hi All-
> > > >> > > >> I just changed the Postgres version to 9.1
> > > >> > > >> install scripts for the applications listed above
> explicitly call out
> > > >> a postgres version (8.4)
> > > >> > > >> Please check your app install scripts as we transition
> to the improved
> > > >> 9.1 postgres base
> > > >> thanks!
> > > >> Brian Hamlin
> > > >> GeoCal
> > > >> 415-717-4462 cell
> > > >> > > >> _______________________________________________
> > > >> Live-demo mailing list
> > > >> Live-demo at lists.osgeo.org
> > > >> http://lists.osgeo.org/mailman/listinfo/live-demo
> > > >> http://live.osgeo.org
> > > >> http://wiki.osgeo.org/wiki/Live_GIS_Disc
> > > > > -- Cameron Shorter
> > > Geospatial Solutions Manager
> > > Tel: +61 (0)2 8570 5050
> > > Mob: +61 (0)419 142 254
> > > > > Think Globally, Fix Locally
> > > Geospatial Solutions enhanced with Open Standards and Open Source
> > > http://www.lisasoft.com
More information about the Live-demo
