[Live-demo] Postgres Apps - MapFish Sahana Rasdaman PGRoutingGPSDrive
Cameron Shorter cameron.shorter at gmail.com
Mon Jan 23 07:43:29 EST 2012
Thanks Daniel, Peter, Brian, Even for your contribution to this discussion.
Based upon Daniel and Peter's concerns about the stability of their
applications, I think that we should revert to Postgres 8.4 for this
release.
Brian, would you mind updating the appropriate install script(s)?
On 23/01/12 11:58, Daniel Kastl wrote:
> pgRouting is probably not going to work with 9.1, because the
> pgRouting packages on Launchpad are built for 8.4 for (X)ubuntu 11.04.
> It would be quite some extra work to just build packages for 9.1 and
> 11.04, which I would like to avoid, because these packages already
> exist for 11.10 (on my PC) and there were some patches necessary. And
> I don't want to revert to a script again to download, compile and
> install ;-)
> So I'm -1 to install some "non-official" PostgreSQL version on this
> LiveDVD release. It will be just a matter of six months to have 9.1
> anyway if we will upgrade to 12.04. IMO, if 9.1 is so important we
> should have used 11.10 for this release.
> Daniel
> On Mon, Jan 23, 2012 at 5:16 AM, <maplabs at light42.com
> <mailto:maplabs at light42.com>> wrote:
>     Compatability for Postgres 9.1 is in the 90% + range
>     The problem people run into is that since Postgres is a
>     fundemental piece of any stack,
>     it is some work to rebuild the stack to test with a new version...
>     I would be surprised if there are any compatability problems at
>     all for most all apps
>     other than people hard-coding version numbers and the like
>       -Brian
>     On Mon, 23 Jan 2012 06:46:57 +1100, Cameron Shorter
>     <cameron.shorter at gmail.com <mailto:cameron.shorter at gmail.com>> wrote:
>     Brian,
>         Based upon Peter's request, my feeling is that we should
>         revert back to Postgres 8.4. Our emphasis on OSGeo-Live is
>         "stability over cutting edge". This is because we are
>         targeting new users who will be very quickly turned off if
>         they find a bug, and will generally not be looking to check
>         out the latest and greatest. (They can always go to a project
>         page later if they want to find latest features). Anyone wish
>         to weigh in on this topic before we make a call on which
>         posgres to use?
>         On 22/01/12 20:55, Peter Baumann wrote:
>         > Hi Brian,
>         > sorry, we have not tested rasdaman with PG 9.x yet. Given
>         the short > time remaining and current project pressure we
>         won't be able to do so > for this DVD roll-out. As in the past
>         even minor release changes in PG > have led to
>         incompatibilities this deserves special attention. We'd >
>         kindly ask you therefore to keep 8.4 available. >
>         > thanks for your understanding,
>         > Peter
>         > On 01/22/2012 06:15 AM, maplabs at light42.com
>         <mailto:maplabs at light42.com> wrote:
>         >> Hi All-
>         >>    I just changed the Postgres version to   9.1
>         >> install scripts for the applications listed above
>         explicitly call out a
>         >> postgres version  (8.4)
>         >> Please check your app install scripts as we transition to
>         the improved
>         >> 9.1 postgres base
>         >> thanks!
>         >> Brian Hamlin
>         >> GeoCal
>         >> OSGeo California Chapter
>         >> 415-717-4462 <tel:415-717-4462> cell
>         >> _______________________________________________
>         >> Live-demo mailing list
>         >> Live-demo at lists.osgeo.org <mailto:Live-demo at lists.osgeo.org>
>         >> http://lists.osgeo.org/mailman/listinfo/live-demo
>         >> http://live.osgeo.org
>         >> http://wiki.osgeo.org/wiki/Live_GIS_Disc
>         -- Cameron Shorter
>         Geospatial Solutions Manager
>         Tel: +61 (0)2 8570 5050 <tel:%2B61%20%280%292%208570%205050>
>         Mob: +61 (0)419 142 254 <tel:%2B61%20%280%29419%20142%20254>
>         Think Globally, Fix Locally
>         Geospatial Solutions enhanced with Open Standards and Open Source
>         http://www.lisasoft.com
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de <http://georepublic.de/>
Cameron Shorter
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20120123/e7a7467c/attachment-0001.html
More information about the Live-demo mailing list
