[Live-demo] [udig-devel] uDig in OSGeoLive 6.0 without JAI
Angelos Tzotsos gcpp.kalxas at gmail.com
Mon Jul 23 11:21:22 PDT 2012
Hi Jody,
On 07/23/2012 08:36 AM, Jody Garnett wrote:
>> We have 2 options:
>> 1. find a way for uDig to load JAI through a custom directory (even
>> though an export LD_LIBRARY_PATH for a custom path did not work in Ubuntu)
> Do you have a link to what you tried in this respect?
> We have an outstanding change request to package the binaries up inside uDig; this would prevent them being shared with other applications
> on the disk; and would result in uDig shipping a second copy of GDAL. While this is smaller then uDig having its own JRE; it would be preferable from a size point of view if you could get the script to work.
I moved the jai binaries and jars into a custom folder under udig.
Then I added this line on start of udig.sh, right under the gdal line:
export LD_LIBRARY_PATH=LD_LIBRARY_PATH:/usr/lib/udig/jai/ext/
>> 2. use a pure java implementation of uDig without JAI
> I am not keen to make a special copy of uDig just for the live dvd.
>> The open ticket is here: https://trac.osgeo.org/osgeo/ticket/922
>> Thoughts?
> You only mentioned JAI here; are you also looking at ImageIO and ImageIO-Ext?  Other projects such as Geomajas are more likely to conflict on the copy of ImageIO-Ext and GDAL used.
I did not touch either ImageIO or GDAL, since udig seemed to open every
file I tested just with JAI moved around.
> Jody
> User-friendly Desktop Internet GIS (uDig)
> http://udig.refractions.net
> http://lists.refractions.net/mailman/listinfo/udig-devel
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20120723/25d94b90/attachment.html>
More information about the Live-demo mailing list
