[Live-demo] [udig-devel] uDig in OSGeoLive 6.0 without JAI
    Frank Gasdorf
    fgdrf at users.sourceforge.net
    Thu Jul 26 14:10:14 PDT 2012
Sorry for cross-posting
Just an short update for everybody who got involved:
1. uDig quickstart on OSGeo Live-Demo completed successfully :D
2. uDig runs with the open-jdk-7 installation with copied JAI/ImageIO
jars and!!! native libs (THX to Angelos again who completed the
udig_install script)
3. geomajas fixed an issue and removed jai libs from war file
Thank you so much for your collaboration on the issue #922
I'm looking forward to get feedback from other testers who can confirm
that uDig and all the other Java projects are fine with this solution.
What do you think about a new ticket to keep in mind that we should
remove this copy task in next release cycle?
Cheers,
Frank
2012/7/26 Angelos Tzotsos <gcpp.kalxas at gmail.com>:
> Thanks Andrea,
> I will be around, please drop by when you can.
> Cheers,
> Angelos
> On 07/26/2012 09:56 AM, andrea antonello wrote:
>> Hi Angelos,
>> I have some doubts about the symbolic linking of the files I see in
>> the track diff.
>> I will try to attend tonights IRC meeting. I have done some packaging
>> (I still do for the osgeo4w project) of jres, but I have to admit that
>> I was not able to follow the discussion completely.
>> In fact I won't be available until one hour after the meeting has been
>> settled, which will be at 10.30 PM my time.
>> I can be online by 11.30 PM my time. Please let me know if that makes
>> even sense.
>> Cheers,
>> Andrea
>> On Thu, Jul 26, 2012 at 2:29 AM, Angelos Tzotsos <gcpp.kalxas at gmail.com>
>> wrote:
>>> Hi Frank, all,
>>> Can you please take a look here:
>>> https://trac.osgeo.org/osgeo/changeset/8349
>>> Comments?
>>> Cheers,
>>> Angelos
>>> On 07/24/2012 11:04 AM, Frank Gasdorf wrote:
>>>> Andrea,
>>>> Absolutely agree, this would not work because of missing jars in
>>>> classpath. I tried to find a way to give the eclipse launcher an
>>>> external classpath but haven't found anything yet. Because of multiple
>>>> classloaders there is no way to work with classpath settings. The RFC
>>>> http://udig.refractions.net/confluence/display/UDIG/native+support+bundles+for+java+advanced+imaging
>>>> would solve this because jai libs and natives are bundled and would
>>>> not required jai in the JRE.
>>>> HACK : What about making symbolic links from udig_home/jre to the
>>>> open-jdk-7 installation files/folders and let the jai/imageio jars
>>>> locally in the lib/ext folder. To make sure udig uses the right JRE
>>>> set the launcher option "-vm" to the udig_home/jre path.
>>>> All other options would require a new release and of course a finished
>>>> RFC ;)  --> next release cycle of OSGeo Live is much more realistic
>>>> BTW: Any news from Andrew about JAI/ImageIO Licensing and
>>>> redistributing as a bundle (see RFC again)
>>>> Cheers,
>>>> Frank
>>>> 2012/7/24 andrea antonello <andrea.antonello at gmail.com>:
>>>>>> I moved the jai binaries and jars into a custom folder under udig.
>>>>>> Then I added this line on start of udig.sh, right under the gdal line:
>>>>>> export LD_LIBRARY_PATH=LD_LIBRARY_PATH:/usr/lib/udig/jai/ext/
>>>>> That would work for the native libs, but then you do not have the jars
>>>>> in the classpath.
>>>>> Also I am not sure if that then picks imageio-ext.
>>>>> I am afraid I am not following this discussion tightly, but the above
>>>>> can't work in my opinion.
>>>>> Frank, you worked on this, do you have opinions about this?
>>>>> Andrea
>>>>>> 2. use a pure java implementation of uDig without JAI
>>>>>> I am not keen to make a special copy of uDig just for the live dvd.
>>>>>> The open ticket is here: https://trac.osgeo.org/osgeo/ticket/922
>>>>>> Thoughts?
>>>>>> You only mentioned JAI here; are you also looking at ImageIO and
>>>>>> ImageIO-Ext?  Other projects such as Geomajas are more likely to
>>>>>> conflict on
>>>>>> the copy of ImageIO-Ext and GDAL used.
>>>>>> I did not touch either ImageIO or GDAL, since udig seemed to open
>>>>>> every
>>>>>> file
>>>>>> I tested just with JAI moved around.
>>>>>> Jody
>>>>>> _______________________________________________
>>>>>> User-friendly Desktop Internet GIS (uDig)
>>>>>> http://lists.refractions.net/mailman/listinfo/udig-devel
>>>>>> Angelos Tzotsos
>>>>>> Remote Sensing Laboratory
>>>>>> National Technical University of Athens
>>>>>> http://users.ntua.gr/tzotsos
>>> Angelos Tzotsos
> Angelos Tzotsos
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo
