[Live-demo] [udig-devel] uDig in OSGeoLive 6.0 without JAI
Jody Garnett
jody.garnett at gmail.com
Thu Jul 26 18:59:52 PDT 2012
Congrats Frank, Angelos, and to Daniele (for pointing out the conflicting Geomajas jars).
That was a fairly epic bug.
Jody Garnett
On Friday, 27 July 2012 at 7:10 AM, Frank Gasdorf wrote:
> Sorry for cross-posting
> Just an short update for everybody who got involved:
> 1. uDig quickstart on OSGeo Live-Demo completed successfully :D
> 2. uDig runs with the open-jdk-7 installation with copied JAI/ImageIO
> jars and!!! native libs (THX to Angelos again who completed the
> udig_install script)
> 3. geomajas fixed an issue and removed jai libs from war file
> Thank you so much for your collaboration on the issue #922
> I'm looking forward to get feedback from other testers who can confirm
> that uDig and all the other Java projects are fine with this solution.
> What do you think about a new ticket to keep in mind that we should
> remove this copy task in next release cycle?
> Cheers,
> Frank
> 2012/7/26 Angelos Tzotsos <gcpp.kalxas at gmail.com (mailto:gcpp.kalxas at gmail.com)>:
> > Thanks Andrea,
> > I will be around, please drop by when you can.
> > Cheers,
> > Angelos
> > On 07/26/2012 09:56 AM, andrea antonello wrote:
> > > Hi Angelos,
> > > I have some doubts about the symbolic linking of the files I see in
> > > the track diff.
> > > I will try to attend tonights IRC meeting. I have done some packaging
> > > (I still do for the osgeo4w project) of jres, but I have to admit that
> > > I was not able to follow the discussion completely.
> > > In fact I won't be available until one hour after the meeting has been
> > > settled, which will be at 10.30 PM my time.
> > > I can be online by 11.30 PM my time. Please let me know if that makes
> > > even sense.
> > > Cheers,
> > > Andrea
> > > On Thu, Jul 26, 2012 at 2:29 AM, Angelos Tzotsos <gcpp.kalxas at gmail.com (mailto:gcpp.kalxas at gmail.com)>
> > > wrote:
> > > > Hi Frank, all,
> > > > Can you please take a look here:
> > > > https://trac.osgeo.org/osgeo/changeset/8349
> > > > Comments?
> > > > Cheers,
> > > > Angelos
> > > > On 07/24/2012 11:04 AM, Frank Gasdorf wrote:
> > > > > Andrea,
> > > > > Absolutely agree, this would not work because of missing jars in
> > > > > classpath. I tried to find a way to give the eclipse launcher an
> > > > > external classpath but haven't found anything yet. Because of multiple
> > > > > classloaders there is no way to work with classpath settings. The RFC
> > > > > http://udig.refractions.net/confluence/display/UDIG/native+support+bundles+for+java+advanced+imaging
> > > > > would solve this because jai libs and natives are bundled and would
> > > > > not required jai in the JRE.
> > > > > HACK : What about making symbolic links from udig_home/jre to the
> > > > > open-jdk-7 installation files/folders and let the jai/imageio jars
> > > > > locally in the lib/ext folder. To make sure udig uses the right JRE
> > > > > set the launcher option "-vm" to the udig_home/jre path.
> > > > > All other options would require a new release and of course a finished
> > > > > RFC ;) --> next release cycle of OSGeo Live is much more realistic
> > > > > BTW: Any news from Andrew about JAI/ImageIO Licensing and
> > > > > redistributing as a bundle (see RFC again)
> > > > > Cheers,
> > > > > Frank
> > > > > 2012/7/24 andrea antonello <andrea.antonello at gmail.com (mailto:andrea.antonello at gmail.com)>:
> > > > > > > I moved the jai binaries and jars into a custom folder under udig.
> > > > > > > Then I added this line on start of udig.sh (http://udig.sh), right under the gdal line:
> > > > > > > export LD_LIBRARY_PATH=LD_LIBRARY_PATH:/usr/lib/udig/jai/ext/
> > > > > > That would work for the native libs, but then you do not have the jars
> > > > > > in the classpath.
> > > > > > Also I am not sure if that then picks imageio-ext.
> > > > > > I am afraid I am not following this discussion tightly, but the above
> > > > > > can't work in my opinion.
> > > > > > Frank, you worked on this, do you have opinions about this?
> > > > > > Andrea
> > > > > > > 2. use a pure java implementation of uDig without JAI
> > > > > > > I am not keen to make a special copy of uDig just for the live dvd.
> > > > > > > The open ticket is here: https://trac.osgeo.org/osgeo/ticket/922
> > > > > > > Thoughts?
> > > > > > > You only mentioned JAI here; are you also looking at ImageIO and
> > > > > > > ImageIO-Ext? Other projects such as Geomajas are more likely to
> > > > > > > conflict on
> > > > > > > the copy of ImageIO-Ext and GDAL used.
> > > > > > > I did not touch either ImageIO or GDAL, since udig seemed to open
> > > > > > > every
> > > > > > > file
> > > > > > > I tested just with JAI moved around.
> > > > > > > Jody
> > > > > > > _______________________________________________
> > > > > > > User-friendly Desktop Internet GIS (uDig)
> > > > > > > http://lists.refractions.net/mailman/listinfo/udig-devel
> > > > > > > Angelos Tzotsos
> > > > > > > Remote Sensing Laboratory
> > > > > > > National Technical University of Athens
> > > > > > > http://users.ntua.gr/tzotsos
> > > > Angelos Tzotsos
> > Angelos Tzotsos
> > Live-demo mailing list
> > Live-demo at lists.osgeo.org (mailto:Live-demo at lists.osgeo.org)
> > http://lists.osgeo.org/mailman/listinfo/live-demo
> > http://live.osgeo.org
> > http://wiki.osgeo.org/wiki/Live_GIS_Disc
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20120727/67b4040b/attachment-0001.html>
More information about the Live-demo
