[Live-demo] 6.0 beta5 Status
Hamish
hamish_b at yahoo.com
Fri Jul 27 15:49:15 PDT 2012
Angelos wrote:
> The new beta is now available for testing:
> Please test and report back any issues found :)
sorry, just loading up the logs and looking at the error reports listed
at the end, it's apparent that something went wrong with it, causing a
bunch of projects to not install correctly (osm, opencpn, openjump,
gpsdrive, mapproxy, mapguide, any probably others).
Specifically, this happened during setup.sh:
dpkg: error: dpkg status database is locked by another process
E: Sub-process /usr/bin/dpkg returned an error code (2)
Which caused gdebi and a bunch of other needed base packages to not be
installed.
if you were not doing anything else at the time, maybe the daily check for
available updates daemon was to blame?
thanks,
Hamish
More information about the Live-demo
