[Live-demo] 6.0 beta5 Status
Angelos Tzotsos
gcpp.kalxas at gmail.com
Fri Jul 27 16:08:00 PDT 2012
Hi Hamish,
I am not sure why this happened.
I installed all applications after that and they work.
I have also moved search for updates to weekly before beta5...
Weird.
On 07/28/2012 01:49 AM, Hamish wrote:
> Angelos wrote:
>> The new beta is now available for testing:
>> Please test and report back any issues found :)
> Hi,
> sorry, just loading up the logs and looking at the error reports listed
> at the end, it's apparent that something went wrong with it, causing a
> bunch of projects to not install correctly (osm, opencpn, openjump,
> gpsdrive, mapproxy, mapguide, any probably others).
> Specifically, this happened during setup.sh:
> dpkg: error: dpkg status database is locked by another process
> E: Sub-process /usr/bin/dpkg returned an error code (2)
> Which caused gdebi and a bunch of other needed base packages to not be
> installed.
> if you were not doing anything else at the time, maybe the daily check for
> available updates daemon was to blame?
> thanks,
> Hamish
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
More information about the Live-demo
