[Live-demo] 6.0 beta5 Status
Angelos Tzotsos gcpp.kalxas at gmail.com
Fri Jul 27 16:27:06 PDT 2012
Update:
After reinstalling those 4 applications everything runs fine.
There is an issue though with Geomoose and pink tiles.
On 07/28/2012 02:08 AM, Angelos Tzotsos wrote:
> Hi Hamish,
> I am not sure why this happened.
> I installed all applications after that and they work.
> I have also moved search for updates to weekly before beta5...
> Weird.
> On 07/28/2012 01:49 AM, Hamish wrote:
>> Angelos wrote:
>>> The new beta is now available for testing:
>>> Please test and report back any issues found :)
>> Hi,
>> sorry, just loading up the logs and looking at the error reports listed
>> at the end, it's apparent that something went wrong with it, causing a
>> bunch of projects to not install correctly (osm, opencpn, openjump,
>> gpsdrive, mapproxy, mapguide, any probably others).
>> Specifically, this happened during setup.sh:
>> dpkg: error: dpkg status database is locked by another process
>> E: Sub-process /usr/bin/dpkg returned an error code (2)
>> Which caused gdebi and a bunch of other needed base packages to not be
>> installed.
>> if you were not doing anything else at the time, maybe the daily
>> check for
>> available updates daemon was to blame?
>> thanks,
>> Hamish
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
More information about the Live-demo mailing list
