[Live-demo] Which version of openjdk should be included on OSGeo-Live 6.0?
Frank Gasdorf
fgdrf at users.sourceforge.net
Mon May 28 22:07:23 PDT 2012
Brian,
please note, that uDig is shipped and installed with its own JRE. To
verify which JRE is used open the "About uDig" Dialog in the launched
Application (Menu -> Help -> About uDig". In the opened Dialog you
will find a "installation Details" Buttown left below, hit it and
switch afterwards to the "Configuration" tab.
For the uDig installation (1.2.2) you will see something like this:
java.home=/usr/lib/udig/jre
java.runtime.version=1.6.0_25-b06
To test against the installed JRE please go through:
* goto /usr/lib/udig with terminal/shell (cd /usr/lib/udig)
* type "sudo mv jre jreXXX" and type the password afterwards (user)
* start uDig again
and in the same About Dialog mentioned above you will see
java.home=/usr/lib/jvm/java-6-openjdk (or something like this, but
not the bundled JRE from /usr/lib/udig)
Start testing the Walkthrough to verify everything is fine:
http://live.osgeo.org/en/quickstart/udig_quickstart.html
Cheers,
Frank
2012/5/29 Brian Hamlin <maplabs at light42.com>:
> Hi All-
> you know that GeoTools and the Java apps are very important to this disk..
> I personally want to get this resolved the best way it can. I also am not a
> Java dev,
> so I am missing a lot of the details under the surface... however
> I just micro tested uDig on the Live build Alpha 2.. all I tried was two
> things..
> Open a shape file, and open a TIF file.. and it worked fine !
> openJDK-6
> so there may be more going on, but it appears to me that we may be able to
> get
> away with openJDK-6. Maybe 7 too..
> best regards from Berkeley, California
> Brian Hamlin
> GeoCal-ish
> OSGeo California Chapter
> 415-717-4462 cell
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo
