[Live-demo] Which version of openjdk should be included on OSGeo-Live 6.0?
    Frank Gasdorf
    fgdrf at users.sourceforge.net
    Mon May 28 22:17:58 PDT 2012
All right. I just tested it on the 5.5 Release and it fails, because of missing
    javax.media.jai.JAI
class. The rendering sub-system requires the Java advanced imaging and
I guess there is no port for openjdk jet.
Because this exception is thrown from a geotools renderer class all
installations that requires geotools would fail. Could anybody confirm
my point of view?
Cheers,
Frank
2012/5/29 Frank Gasdorf <fgdrf at users.sourceforge.net>:
> Brian,
> please note, that uDig is shipped and installed with its own JRE. To
> verify which JRE is used open the "About uDig" Dialog in the launched
> Application (Menu -> Help -> About uDig". In the opened Dialog you
> will find a "installation Details" Buttown left below, hit it and
> switch afterwards to the "Configuration" tab.
> For the uDig installation (1.2.2) you will see something like this:
> java.home=/usr/lib/udig/jre
> java.runtime.version=1.6.0_25-b06
> To test against the installed JRE please go through:
> * goto /usr/lib/udig with terminal/shell (cd /usr/lib/udig)
> * type "sudo mv jre jreXXX" and type the password afterwards (user)
> * start uDig again
> and in the same About Dialog mentioned above you will see
> java.home=/usr/lib/jvm/java-6-openjdk   (or something like this, but
> not the bundled JRE from /usr/lib/udig)
> Start testing the Walkthrough to verify everything is fine:
> http://live.osgeo.org/en/quickstart/udig_quickstart.html
> Cheers,
> Frank
> 2012/5/29 Brian Hamlin <maplabs at light42.com>:
>> Hi All-
>>  you know that GeoTools and the Java apps are very important to this disk..
>>  I personally want to get this resolved the best way it can. I also am not a
>> Java dev,
>> so I am missing a lot of the details under the surface...  however
>>  I just micro tested uDig on the Live build Alpha 2.. all I tried was two
>> things..
>> Open a shape file, and open a TIF file.. and it worked fine !
>>  openJDK-6
>>  so there may be more going on, but it appears to me that we may be able to
>> get
>> away with openJDK-6. Maybe 7 too..
>>  best regards from Berkeley, California
>> Brian Hamlin
>> GeoCal-ish
>> OSGeo California Chapter
>> 415-717-4462 cell
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo
