[Live-demo] uDig and open-jdk (was Which version of openjdk...)
Brian Hamlin
maplabs at light42.com
Mon May 28 22:35:14 PDT 2012
yes Frank you are right
disabling the jre included with uDig causes rendering errors
for both SHP file and TIF
On May 28, 2012, at 10:07 PM, Frank Gasdorf wrote:
> Brian,
> please note, that uDig is shipped and installed with its own JRE. To
> verify which JRE is used open the "About uDig" Dialog in the launched
> Application (Menu -> Help -> About uDig". In the opened Dialog you
> will find a "installation Details" Buttown left below, hit it and
> switch afterwards to the "Configuration" tab.
> For the uDig installation (1.2.2) you will see something like this:
> java.home=/usr/lib/udig/jre
> java.runtime.version=1.6.0_25-b06
> To test against the installed JRE please go through:
> * goto /usr/lib/udig with terminal/shell (cd /usr/lib/udig)
> * type "sudo mv jre jreXXX" and type the password afterwards (user)
> * start uDig again
> and in the same About Dialog mentioned above you will see
> java.home=/usr/lib/jvm/java-6-openjdk (or something like this, but
> not the bundled JRE from /usr/lib/udig)
> Start testing the Walkthrough to verify everything is fine:
> http://live.osgeo.org/en/quickstart/udig_quickstart.html
> Cheers,
> Frank
> 2012/5/29 Brian Hamlin <maplabs at light42.com>:
>> Hi All-
>> you know that GeoTools and the Java apps are very important to
>> this disk..
>> I personally want to get this resolved the best way it can. I
>> also am not a
>> Java dev,
>> so I am missing a lot of the details under the surface... however
>> I just micro tested uDig on the Live build Alpha 2.. all I tried
>> was two
>> things..
>> Open a shape file, and open a TIF file.. and it worked fine !
>> openJDK-6
>> so there may be more going on, but it appears to me that we may
>> be able to
>> get
>> away with openJDK-6. Maybe 7 too..
>> best regards from Berkeley, California
>> Brian Hamlin
>> GeoCal-ish
>> OSGeo California Chapter
>> 415-717-4462 cell
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo
