[Live-demo] ossim build
Pieter du Plooy pjduplooy at zpanelcp.com
Fri Sep 14 01:54:10 PDT 2012
Hi guys
I have been using the install script for ossim from the current trunk.
I had to edit the installer so that openscenegraph is commented out, as I
have built it manually from source.
Install went fine, but as soon as I use iview or ossimplanet, I get wrong
elf class errors.  I am using 64 bit, so all apps are built in 64 bit.
Is it perhaps that the ossim downloaded as part of the install was built
for 32 bit?
Any solution to this?
Any help would be appreciated.
Regards
Pieter
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20120914/8c541974/attachment.html>
More information about the Live-demo mailing list
