[Live-demo] ossim build
Cameron Shorter
cameron.shorter at gmail.com
Fri Sep 14 13:06:18 PDT 2012
Pieter,
I'm CCing Pirmin and Massimo who have been looking after the packaging
of OSSIM on OSGeo-Live and might have an answer for you.
Your theory about 64bit/32bit might be accurate. OSGeo-Live is built for
a 32bit system.
On 14/09/12 18:54, Pieter du Plooy wrote:
> Hi guys
> I have been using the install script for ossim from the current trunk.
> I had to edit the installer so that openscenegraph is commented out,
> as I have built it manually from source.
> Install went fine, but as soon as I use iview or ossimplanet, I get
> wrong elf class errors. I am using 64 bit, so all apps are built in
> 64 bit.
> Is it perhaps that the ossim downloaded as part of the install was
> built for 32 bit?
> Any solution to this?
> Any help would be appreciated.
> Regards
> Pieter
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20120915/9771de58/attachment.html>
More information about the Live-demo
