[Live-demo] Minor issue with Iris
Angelos Tzotsos
gcpp.kalxas at gmail.com
Tue Aug 13 07:19:06 PDT 2013
Fixed in http://trac.osgeo.org/osgeo/changeset/10749
On Tue, Aug 13, 2013 at 5:15 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com>wrote:
> Hi Ian,
> This package is uninstalled from the same install_iris.sh script in line
> 98.
> So the fix is easy.
> Best regards,
> Angelos
> On Tue, Aug 13, 2013 at 4:48 PM, Ian Edwards <iedwards.pub at gmail.com>wrote:
>> Hi All,
>> I'm not sure when it broke, but there is currently an issue with the
>> installed version of Iris that appears to be due to correctly cleaning up
>> "-dev" packages.
>> The current Iris install script correctly installs the "libudunits2-dev"
>> package (833 kb), but I assume a later step in the process must be removing
>> this - and removing the dev package must also be removing the "libudunits2-0"
>> package which is required at run time.
>> $ apt-get install libudunits2-dev
>> The following NEW packages will be installed
>> libudunits2-0 libudunits2-dev
>> After this operation, 833 kB of additional disk space will be used.
>> What is the best way to fix this? I'm unsure whether separately adding
>> the run time package to the install script is a good idea?...
>> Many thanks
>> Ian
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://live.osgeo.org
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
> Angelos Tzotsos
> Remote Sensing Laboratory
> National Technical University of Athens
> http://users.ntua.gr/tzotsos
Angelos Tzotsos
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20130813/c8124385/attachment.html>
More information about the Live-demo
