[Live-demo] Minor issue with Iris
Angelos Tzotsos gcpp.kalxas at gmail.com
Tue Aug 13 07:15:42 PDT 2013
Hi Ian,
This package is uninstalled from the same install_iris.sh script in line 98.
So the fix is easy.
Best regards,
Angelos
On Tue, Aug 13, 2013 at 4:48 PM, Ian Edwards <iedwards.pub at gmail.com> wrote:
> Hi All,
> I'm not sure when it broke, but there is currently an issue with the
> installed version of Iris that appears to be due to correctly cleaning up
> "-dev" packages.
> The current Iris install script correctly installs the "libudunits2-dev"
> package (833 kb), but I assume a later step in the process must be removing
> this - and removing the dev package must also be removing the "libudunits2-0"
> package which is required at run time.
> $ apt-get install libudunits2-dev
> The following NEW packages will be installed
>   libudunits2-0 libudunits2-dev
> After this operation, 833 kB of additional disk space will be used.
> What is the best way to fix this? I'm unsure whether separately adding the
> run time package to the install script is a good idea?...
>  Many thanks
> Ian
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20130813/2814813a/attachment.html>
More information about the Live-demo mailing list
