[Live-demo] [OSGeo] #1224: Spatialite version conflict
OSGeo
trac_osgeo at osgeo.org
Sat Aug 24 04:00:05 PDT 2013
Reporter: micha | Owner: live-demo@…
Type: defect | Status: new
Priority: blocker | Milestone: OSGeoLive7.0
Component: LiveDVD | Keywords: spatialite, qgis, libspatialite
We now have on the LiveDVD two versions of libspatialite, both
libspatialite3 '''and''' libspatialite5. The second is brought in by
PostGIS, and causes spatialite_gui to use the version 4.1 of the library
instead of the version 3.1 we had up till recently. This is bad news.
The botton line in that any DB created in spatialite is '''unreadable by
QGIS ''' !
I know we're "5 minutes" before the final build, but this problem will
really reflect badly on QGIS, SpatiaLite and the LiveDVD.
Two thoughts for a solution:
I wonder if the install_spatialite.sh were run in the build process
'''before''' PostGIS gets installed, then it would compile spatialite_gui
using the libspatialite3 libraries.
Alternatively, we could put into the ./configure script for spatialite_gui
an explicit path to the libspatialite3 *.so rather than depending on
pkg_config.
Any additional thoughts welcome.
Thanks,
Micha
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1224>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
