[Live-demo] Master for printing
Ian Edwards iedwards.pub at gmail.com
Mon Aug 26 10:39:01 PDT 2013
Just wanted to check this before ordering 800 copies...
Downloaded ISO and md5 check: OK
Burned ISO and used software's verify option: ok
Ran md5sum -c md5sum.text on the disc contents...
  1 computed checksum did NOT match
  ./isolinix/isolinux.bin: FAILED
Is the md5sum.txt file generated before isolinux.bin is finalised?
The disc boots into OSGeo Live fine.
Actual md5 for isolinux.bin:
098b04f6a80f1352c3b51e0d45bfad9f  isolinux/isolinux.bin
On 25 Aug 2013 04:27, "Hamish" <hamish_b at yahoo.com> wrote:
Hi all,
I've just tagged the osgeolive_7_0 branch in SVN. This doesn't mean that
testing is done, just that any bug fixes that come in to trunk need to be
backported (deep freeze). I'll wait until we send the master image to the
printers before tagging the release.
Now's a great time to download RC2 and test (a) your favourite geosoftware
and (b) try out a new one while you're at it. Greek and Californian mirrors:
http://aiolos.survey.ntua.gr/gisvm/7.0/
http://osprey.ucdavis.edu/downloads/osgeo/gisvm/gisvm/7.0rc2/
Note you'll need the Mini version if you are installing to a 4GB USB stick.
After many false starts, this will be the first release with persistent
disc space for 4GB usb drives possible. There's not very much space to work
with (415mb in theory, probably half that in practice) but it's a start.
Note the read-only USBs (the default) will be faster since the writing
process is to RAM disk there. You have to be in an OSGeoLive 6.5 or 7.0
session to enable the option in the startup disc creator tool.
Feedback to #osgeolive on the Freenode network, and the osgeo bug trac'er.
thanks,
Hamish
Live-demo mailing list
Live-demo at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/live-demo
http://live.osgeo.org
http://wiki.osgeo.org/wiki/Live_GIS_Disc
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20130826/4e607a95/attachment.html>
More information about the Live-demo mailing list
