[Live-demo] Master for printing
Angelos Tzotsos
gcpp.kalxas at gmail.com
Mon Aug 26 10:43:38 PDT 2013
Hi Ian,
As long as the downloaded iso passes the md5 check and you have managed to
burn the iso and boot from it, I believe that everything is ok.
Best,
Angelos
On Mon, Aug 26, 2013 at 8:39 PM, Ian Edwards <iedwards.pub at gmail.com> wrote:
> Just wanted to check this before ordering 800 copies...
> Downloaded ISO and md5 check: OK
> Burned ISO and used software's verify option: ok
> Ran md5sum -c md5sum.text on the disc contents...
> 1 computed checksum did NOT match
> ./isolinix/isolinux.bin: FAILED
> Is the md5sum.txt file generated before isolinux.bin is finalised?
> The disc boots into OSGeo Live fine.
> Actual md5 for isolinux.bin:
> 098b04f6a80f1352c3b51e0d45bfad9f isolinux/isolinux.bin
> On 25 Aug 2013 04:27, "Hamish" <hamish_b at yahoo.com> wrote:
> Hi all,
> I've just tagged the osgeolive_7_0 branch in SVN. This doesn't mean that
> testing is done, just that any bug fixes that come in to trunk need to be
> backported (deep freeze). I'll wait until we send the master image to the
> printers before tagging the release.
> Now's a great time to download RC2 and test (a) your favourite geosoftware
> and (b) try out a new one while you're at it. Greek and Californian mirrors:
> http://aiolos.survey.ntua.gr/gisvm/7.0/
> http://osprey.ucdavis.edu/downloads/osgeo/gisvm/gisvm/7.0rc2/
> Note you'll need the Mini version if you are installing to a 4GB USB
> stick. After many false starts, this will be the first release with
> persistent disc space for 4GB usb drives possible. There's not very much
> space to work with (415mb in theory, probably half that in practice) but
> it's a start. Note the read-only USBs (the default) will be faster since
> the writing process is to RAM disk there. You have to be in an OSGeoLive
> 6.5 or 7.0 session to enable the option in the startup disc creator tool.
> Feedback to #osgeolive on the Freenode network, and the osgeo bug trac'er.
> thanks,
> Hamish
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20130826/63d481d3/attachment-0001.html>
More information about the Live-demo
