[Live-demo] Master for printing
Brian Hamlin
maplabs at light42.com
Mon Aug 26 11:21:10 PDT 2013
The MD5 checksum is sensitive to the byte, so it confirms you have an
exact copy. I suspect that the MD5 on the .iso file is one check, and
then an MD5 *on the physical media* is the second check. Past that.
it is up to the DVD duplicators to do their job.
Please note that the USB sticks - 4GB or 8GB - have been popular in
the past, but that even professional duplicators who swear that they
can do it, have failed in the past to make them correctly. As noted
on the master spreadsheet, our team has, including me, have burned a
bootable USB with the OSGeo Live 7.
The DVD duplication should be straightforward.
best regards from Berkeley, California
Brian M Hamlin
OSGeo California Chapter
osgeo,org
On Aug 26, 2013, at 10:43 AM, Angelos Tzotsos wrote:
> Hi Ian,
> As long as the downloaded iso passes the md5 check and you have
> managed to burn the iso and boot from it, I believe that everything
> is ok.
> Best,
> Angelos
> On Mon, Aug 26, 2013 at 8:39 PM, Ian Edwards
> <iedwards.pub at gmail.com> wrote:
> Just wanted to check this before ordering 800 copies...
> Downloaded ISO and md5 check: OK
> Burned ISO and used software's verify option: ok
> Ran md5sum -c md5sum.text on the disc contents...
> 1 computed checksum did NOT match
> ./isolinix/isolinux.bin: FAILED
> Is the md5sum.txt file generated before isolinux.bin is finalised?
> The disc boots into OSGeo Live fine.
> Actual md5 for isolinux.bin:
> 098b04f6a80f1352c3b51e0d45bfad9f isolinux/isolinux.bin
> On 25 Aug 2013 04:27, "Hamish" <hamish_b at yahoo.com> wrote:
> Hi all,
> I've just tagged the osgeolive_7_0 branch in SVN. This doesn't mean
> that testing is done, just that any bug fixes that come in to trunk
> need to be backported (deep freeze). I'll wait until we send the
> master image to the printers before tagging the release.
> Now's a great time to download RC2 and test (a) your favourite
> geosoftware and (b) try out a new one while you're at it. Greek and
> Californian mirrors:
> http://aiolos.survey.ntua.gr/gisvm/7.0/
> http://osprey.ucdavis.edu/downloads/osgeo/gisvm/gisvm/7.0rc2/
> Note you'll need the Mini version if you are installing to a 4GB
> USB stick. After many false starts, this will be the first release
> with persistent disc space for 4GB usb drives possible. There's not
> very much space to work with (415mb in theory, probably half that
> in practice) but it's a start. Note the read-only USBs (the
> default) will be faster since the writing process is to RAM disk
> there. You have to be in an OSGeoLive 6.5 or 7.0 session to enable
> the option in the startup disc creator tool.
> Feedback to #osgeolive on the Freenode network, and the osgeo bug
> trac'er.
> thanks,
> Hamish
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
> Angelos Tzotsos
> Remote Sensing Laboratory
> National Technical University of Athens
> http://users.ntua.gr/tzotsos
More information about the Live-demo
