[Live-demo] Artwork for version 6.5?
Anton Popov
mail at antonpopov.de
Wed Feb 20 11:45:42 PST 2013
Hi Javi
I'm the one who created the first version [1] of the cover you
mentioned. It's designed to provide a basic layout while allowing a
custom (e.g. yearly) theme. I'm in the process of upgrading the design
to the current version 6.5. In order to make it easier for people like
you to develop own customizations I'm simplifying the XCF. Once done
I'll upload it to the SVN (might take a week or two since I'm busy with
other stuff right now).
To give you an impression of how the design is intended to be used:
The cover for the german FOSSGIS of this year can be found here [2] and
there [3]. Last year's version was this [4] and that [5]. There should
also be a version around in [1] - without any theme - that looks like
[6] and [7].
The design was created using GIMP 2.7. So yes, as you already noticed,
the design is raster based. With a setting of 300 dpi it should be
printed right to the size of a CD/DVD hull (12.1 cm). I'm afraid there
is no vector version of the main background image available. That's why
I decided to do it raster-based.
When working with the XCF there are a few things you should be aware
of:
* There are a few hidden layers like guides or logos. Don't get
confused by this. Just ignore or remove them ;)
* When moving layers make sure that there are no unwanted/unrelated
layers linked together (see the chain icon next to the visibility
icon in the layer list) so that you don't move other layers by
accident. Some of the layers are already linked by default in [1]!
* There are many layers that make heavy use of transparency. Some of
them exist multiple times to enable you to increase or decrease the
effect. Link/unlink them before/after moving so that their position
matches.
* As a policy: when creating text layers create duplicates of them,
run a gaussian filter (at a fitting size, of course) and invert the
colors (or use white as a rule of thumb). Since the backgound image
contains darker and lighter colors this makes it easier to read the
text.
* Concerning giving assignments to a printing company: the XCF's
contain some (later invisible) guides. You should mainly work
within these bounds. And: any new background image you add should
overlap those guides. This is also called "bleeding". When the
printed paper is cut there won't be white border artifacts this
way.
I hope I wrote understandable and you feel introduced enough =)
If you have any questions, please let me know. I'll commit a simpler
template for future versions as soon as possible.
Kind regards,
Anton Popov
[1] http://trac.osgeo.org/osgeo/browser/livedvd/artwork/sleeve/5.5
[2] http://www.fossgis.de/wiki/Datei:OSGeo_Live_6.5_booklet_outside.png
[3] http://www.fossgis.de/wiki/Datei:OSGeo_Live_6.5_DVD-final.png
[4] http://www.fossgis.de/wiki/Datei:OSGeo_Live_5.5_booklet_outside.png
[5] http://www.fossgis.de/wiki/Datei:OSGeo_Live_5_5_DVD-final.png
[6] http://antonpopov.de/gfx/osgeo/03-01-nofossgis-noframe.png
[7] http://antonpopov.de/gfx/osgeo/03-01-nofossgis.png
On [20.02.13 14:13], Javi Sanchez wrote:
> Hi all,
> I Just would like to know if there is someone already working on new
> artwork version of the disc.
> I also wonder if someone could give me any tip/help on how to work
> on it and if it is possible to fix it with GIMP.
> I've been taking a look at [1], but those files seems to be raster
> when I open them in GIMP, I understand it is not easy to edit unless
> I can have them in vector format. Is that correct or I just don't
> know how to do it?
> [1] http://trac.osgeo.org/osgeo/browser/livedvd/artwork/sleeve/6.0
> Best regards,
> Javi Sánchez.
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20130220/d841d474/attachment.pgp>
More information about the Live-demo
