[Live-demo] errors and warnings from the latest nightly build
Hamish
hamish_b at yahoo.com
Sun Jan 27 15:48:22 PST 2013
the following are error and warning messages grep'd from the
latest nightly build (run a few hours ago).
I make a few comments inline. Some/most may be false positives,
but some look more serious. please have a look.
http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-debug-build9634-log.tar.gz
thanks,
Hamish
5335:mysqlcheck: Got error: 2002: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2) when trying to connect
5348:ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
7701:psql:/usr/share/postlbs/routing_core_wrappers.sql:106: ERROR: type "geometry" does not exist
7702:psql:/usr/share/postlbs/routing_core_wrappers.sql:149: ERROR: type "geoms" does not exist
7703:psql:/usr/share/postlbs/routing_core_wrappers.sql:199: ERROR: type "geoms" does not exist
7704:psql:/usr/share/postlbs/routing_core_wrappers.sql:248: ERROR: type "geoms" does not exist
7705:psql:/usr/share/postlbs/routing_core_wrappers.sql:397: ERROR: type "geoms" does not exist
7706:psql:/usr/share/postlbs/routing_core_wrappers.sql:449: ERROR: type "geoms" does not exist
7707:psql:/usr/share/postlbs/routing_core_wrappers.sql:591: ERROR: type "geoms" does not exist
7708:psql:/usr/share/postlbs/routing_core_wrappers.sql:639: ERROR: type "geoms" does not exist
7709:psql:/usr/share/postlbs/routing_core_wrappers.sql:775: ERROR: type "geoms" does not exist
7710:psql:/usr/share/postlbs/routing_core_wrappers.sql:831: ERROR: type "geoms" does not exist
7711:psql:/usr/share/postlbs/routing_core_wrappers.sql:908: ERROR: type "geoms" does not exist
7712:psql:/usr/share/postlbs/routing_core_wrappers.sql:943: ERROR: type "geoms" does not exist
7713:psql:/usr/share/postlbs/routing_core_wrappers.sql:998: ERROR: type "geoms" does not exist
7714:psql:/usr/share/postlbs/routing_core_wrappers.sql:1133: ERROR: type "geoms" does not exist
7715:psql:/usr/share/postlbs/routing_topology.sql:45: ERROR: type geometry does not exist
7717:psql:/usr/share/postlbs/routing_tsp_wrappers.sql:96: ERROR: type "geoms" does not exist
7718:psql:/usr/share/postlbs/routing_tsp_wrappers.sql:157: ERROR: type "geoms" does not exist
7719:psql:/usr/share/postlbs/routing_tsp_wrappers.sql:202: ERROR: type "geoms" does not exist
7720:psql:/usr/share/postlbs/routing_tsp_wrappers.sql:265: ERROR: type "geoms" does not exist
7722:psql:/usr/share/postlbs/routing_dd_wrappers.sql:75: ERROR: type "geoms" does not exist
7723:psql:/usr/share/postlbs/routing_dd_wrappers.sql:117: ERROR: type "geoms" does not exist
8118:ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
[mapbender]
8410:createdb: database creation failed: ERROR: template database "template_postgis" does not exist
9330:Download error on https://geopython.github.com/OWSLib: [Errno 111] Connection refused -- Some packages may not be found!
9332:Download error on https://geopython.github.com/OWSLib: [Errno 111] Connection refused -- Some packages may not be found!
9334:Download error on https://geopython.github.com/OWSLib: [Errno 111] Connection refused -- Some packages may not be found!
20337:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:3: ERROR: table "ps_multipoint" does not exist
20338:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:4: ERROR: table "ps_multisolid" does not exist
20339:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:5: ERROR: table "ps_multisurface" does not exist
20340:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:6: ERROR: table "ps_multicurve" does not exist
20341:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:9: ERROR: table "ps_crsdetails" does not exist
20342:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:10: ERROR: table "ps_descriptions" does not exist
20343:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:11: ERROR: table "ps_crsset" does not exist
20344:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:12: ERROR: table "ps_nullset" does not exist
20345:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:13: ERROR: table "ps_interpolationset" does not exist
20346:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:14: ERROR: table "ps_range" does not exist
20347:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:15: ERROR: table "ps_domain" does not exist
20348:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:16: ERROR: table "ps_celldomain" does not exist
20349:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:17: ERROR: table "ps_coverage" does not exist
20350:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:18: ERROR: table "ps_format" does not exist
20351:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:19: ERROR: table "ps_crs" does not exist
20352:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:20: ERROR: table "ps_nullresistance" does not exist
20353:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:21: ERROR: table "ps_interpolationtype" does not exist
20354:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:22: ERROR: table "ps_datatype" does not exist
20355:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:23: ERROR: table "ps_axistype" does not exist
20356:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:24: ERROR: table "ps_uom" does not exist
20357:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:25: ERROR: table "ps_dbupdates" does not exist
20358:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:27: ERROR: table "ps_styles" does not exist
20359:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:28: ERROR: table "ps_pyramidlevels" does not exist
20360:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:29: ERROR: table "ps_servicelayer" does not exist
20361:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:30: ERROR: table "ps_services" does not exist
20362:psql:/tmp/build_rasdaman/rasdaman/applications/petascope/db/droptables.sql:31: ERROR: table "ps_layers" does not exist
make[1]: Entering directory `/tmp/build_rasdaman/rasdaman_data_8-3/DataImport/mowglie'
make[1]: Nothing to be done for `init'.
make[1]: Leaving directory `/tmp/build_rasdaman/rasdaman_data_8-3/DataImport/mowglie'
make[1]: Entering directory `/tmp/build_rasdaman/rasdaman_data_8-3/DataImport/timeseries'
make[1]: *** No rule to make target `init'. Stop.
make[1]: Leaving directory `/tmp/build_rasdaman/rasdaman_data_8-3/DataImport/timeseries'
20946:make: *** [init] Error 2
22935:E: Unable to locate package gvsig
32167:ERROR: database "cartaro" does not exist
32168:ERROR: role "cartaro" does not exist
32241:27 Jan 18:47:14 ERROR [geoserver.global] -
32497:27 Jan 18:48:29 ERROR [geoserver.rest] - No such workspace: cartaro
32498:27 Jan 18:48:29 ERROR [geoserver.rest] -
32581:27 Jan 18:48:29 ERROR [geoserver.rest] - No such datastore: cartaro,cartaro
32582:27 Jan 18:48:29 ERROR [geoserver.rest] -
32667:27 Jan 18:48:39 ERROR [geoserver.rest] - No such feature type: cartaro,cartaro,capitals
32668:27 Jan 18:48:39 ERROR [geoserver.rest] -
-->HB: (I assume those are created as part of the psql command?)
--> [many, many Java errors for cartaro]
32752:org.postgresql.util.PSQLException: ERROR: permission denied for relation geography_columns
--> that sounds potentially bad.
sh: 1: /usr/sbin/sendmail: not found
32856:WD mail: Error sending e-mail (from admin at example.com to
32859:Unable to send e-mail. Contact the site administrator if the problem
32887:27 Jan 18:48:54 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name 'geoServerLoader': org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name 'GWCLifeCycleHandler': Singleton bean creation not allowed while the singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
34996:/usr/local/share/gisvm/doc/ca/quickstart/cartaro_quickstart.rst:50: ERROR: Undefined substitution referenced: "osgeolive-Other-Start Cartaro".
35000:/usr/local/share/gisvm/doc/de/quickstart/cartaro_quickstart.rst:50: ERROR: Undefined substitution referenced: "osgeolive-Other-Start Cartaro".
35004:/usr/local/share/gisvm/doc/el/quickstart/cartaro_quickstart.rst:30: ERROR: Undefined substitution referenced: "osgeolive-Other-Start Cartaro".
35013:/usr/local/share/gisvm/doc/en/quickstart/cartaro_quickstart.rst:50: ERROR: Undefined substitution referenced: "osgeolive-Other-Start Cartaro".
35025:/usr/local/share/gisvm/doc/es/quickstart/cartaro_quickstart.rst:50: ERROR: Undefined substitution referenced: "osgeolive-Other-Start Cartaro".
35028:/usr/local/share/gisvm/doc/fr/quickstart/cartaro_quickstart.rst:50: ERROR: Undefined substitution referenced: "osgeolive-Other-Start Cartaro".
35044:/usr/local/share/gisvm/doc/it/quickstart/cartaro_quickstart.rst:50: ERROR: Undefined substitution referenced: "osgeolive-Other-Start Cartaro".
35055:/usr/local/share/gisvm/doc/it/quickstart/mapserver_quickstart.rst:111: ERROR: Unexpected indentation.
35063:/usr/local/share/gisvm/doc/it/quickstart/osgeolive_quickstart.rst:65: ERROR: Unexpected indentation.
35067:/usr/local/share/gisvm/doc/it/quickstart/rasdaman_quickstart.rst:50: ERROR: Unknown target name: "i suoi prerequisiti<http://kahlua.eecs.jacobs-university.de/trac/rasdaman/wiki/requiredpackages>".
35069:/usr/local/share/gisvm/doc/it/quickstart/tinyows_quickstart.rst:96: ERROR: Unknown target name: "documentazione di tinyows".
35072:/usr/local/share/gisvm/doc/ja/quickstart/cartaro_quickstart.rst:50: ERROR: Undefined substitution referenced: "osgeolive-Other-Start Cartaro".
35076:/usr/local/share/gisvm/doc/ko/quickstart/cartaro_quickstart.rst:50: ERROR: Undefined substitution referenced: "osgeolive-Other-Start Cartaro".
35144:/usr/local/share/gisvm/doc/pl/overview/geos_overview.rst:34: ERROR: Unexpected indentation.
35234:/usr/local/share/gisvm/doc/pl/quickstart/cartaro_quickstart.rst:50: ERROR: Undefined substitution referenced: "osgeolive-Other-Start Cartaro".
35274:/usr/local/share/gisvm/doc/ru/quickstart/R_quickstart.rst:68: ERROR: Unexpected indentation.
35275:/usr/local/share/gisvm/doc/ru/quickstart/cartaro_quickstart.rst:50: ERROR: Undefined substitution referenced: "osgeolive-Other-Start Cartaro".
35294:/usr/local/share/gisvm/doc/ru/quickstart/mapwindow_quickstart.rst:69: ERROR: Malformed table.
35363:/usr/local/share/gisvm/doc/ru/quickstart/mapwindow_quickstart.rst:293: ERROR: Malformed table.
35444:/usr/local/share/gisvm/doc/zh/quickstart/cartaro_quickstart.rst:50: ERROR: Undefined substitution referenced: "osgeolive-Other-Start Cartaro".
<end of cartaro errors>
mv: cannot stat `atlasstyler.desktop': No such file or directory
mv: cannot stat `geopublisher.desktop': No such file or directory
mv: cannot stat `mapguide*.desktop': No such file or directory
mv: cannot stat `i3geo.desktop': No such file or directory
-->HB: (I assume those are all supposed to be missing, right?)
sed: can't read /etc/ssh/sshd_config: No such file or directory
sed: can't read extract-cd/.disk/info: No such file or directory
ls: cannot access /var/run/mysqld/mysqld.sock: No such file or directory
3418:invoke-rc.d: initscript apparmor, action "start" failed.
3422:invoke-rc.d: initscript apparmor, action "reload" failed.
3459:Failed to open connection to "system" message bus: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
3610:WARNING:softwarecenter.db.update:Failed to setup dbus (ignoring)
5931:GeoMajas FIXME: *** Do not use 777 if at all possible. ***
10576:FIXME: libLAS should be supplied in .deb form. This is low hanging fruit.
11293:FIXME: (libLAS) make sure we haven't lost any important automatically installed pkgs
11599:/tmp/easy_install-_U3pFG/Shapely-1.2.8/setup.py:10: Warning: Failed to import distribute_setup, continuing without distribute.
32751:27 Jan 18:48:40 WARN [geotools.jdbc] - Failed to retrieve information about public.geoserver_capitals_view.field_location_geometry from the geometry_columns table, checking geometry_columns instead
More information about the Live-demo
