[Live-demo] JAVA_OPTS global ?
Jody Garnett
jody.garnett at gmail.com
Wed Jul 10 17:07:18 PDT 2013
We tend to do a small shell script to launch the application (double check JAVA_HOME location, and set and environmental variables needed).
You can see an example in the uDig install.
Jody Garnett
On Wednesday, 10 July 2013 at 7:32 AM, maplabs at light42.com wrote:
> Hi Hamish, All -
> Brian in "learning mode" here... http://trac.osgeo.org/osgeo/changeset/10340
> Where is the best place to enable JSONP ? as noted, I suspect that it is additive, and does not remove behavior for other apps, so in that single case, it may be harmless to enable globally..
> With regards to XX:MaxPermSize and other memory settings.. I infer that the Java ecosystem has some not-clearly resolved architectural challenges .. I seem to recall that I saw multiple, apparently conflicting memory settings on another environment, due to search paths and other unsightly details of reality.. It appeared to me at the time that the "biggest setting won" and Java VM got the most memory of any of the settings.. specifically not "last one wins" or variations of that..
> I am all ears as to where the right place to set these flags might be.. Java practitioners, opinion?
> Brian M Hamlin
> OSGeo California Chapter
> Live-demo mailing list
> Live-demo at lists.osgeo.org (mailto:Live-demo at lists.osgeo.org)
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20130711/a1d8cdb3/attachment.html>
More information about the Live-demo
