[Live-demo] Unable to build documentation
Guy Griffiths
guy.griffiths at reading.ac.uk
Fri Jul 12 02:44:14 PDT 2013
I am trying to build the documentation for OSGeo-Live so that I can
confirm that my .rst files are translating to the correct HTML.
I am using Python 2.7.4 and Sphinx 1.1.3 on Ubuntu 13.04 and I get a
build error (traceback included at the end of this email). All
documentation is up-to-date with the version on SVN.
If anyone could help with this I'd be very grateful - whilst I can check
the documentation using the nightly ISO builds it's far from the most
efficient way!
Regards,
Guy Griffiths
Traceback from logs:
# Sphinx version: 1.1.3
# Python version: 2.7.4
# Docutils version: 0.10 release
# Jinja2 version: 2.6
File "/usr/lib/python2.7/dist-packages/sphinx/cmdline.py", line 189,
in main
app.build(force_all, filenames)
File "/usr/lib/python2.7/dist-packages/sphinx/application.py", line
204, in build
self.builder.build_update()
File "/usr/lib/python2.7/dist-packages/sphinx/builders/__init__.py",
line 196, in build_update
'out of date' % len(to_build))
line 252, in build
self.write(docnames, list(updated_docnames), method)
line 292, in write
self.write_doc(docname, doctree)
File "/usr/lib/python2.7/dist-packages/sphinx/builders/html.py", line
419, in write_doc
self.docwriter.write(doctree, destination)
File "/usr/lib/python2.7/dist-packages/docutils/writers/__init__.py",
line 80, in write
self.translate()
File "/usr/lib/python2.7/dist-packages/sphinx/writers/html.py", line
38, in translate
self.document.walkabout(visitor)
File "/usr/lib/python2.7/dist-packages/docutils/nodes.py", line 174,
in walkabout
if child.walkabout(visitor):
in walkabout
in walkabout
in walkabout
File "/usr/lib/python2.7/dist-packages/docutils/nodes.py", line 166,
in walkabout
visitor.dispatch_visit(self)
File "/usr/lib/python2.7/dist-packages/docutils/nodes.py", line 1627,
in dispatch_visit
return method(node)
377, in visit_image
BaseTranslator.visit_image(self, node)
File
"/usr/lib/python2.7/dist-packages/docutils/writers/html4css1/__init__.py",
line 1032, in visit_image
and self.settings.file_insertion_enabled):
AttributeError: Values instance has no attribute 'file_insertion_enabled'
More information about the Live-demo
