[Live-demo] OSGeoLive 7.0 status: beta1
Daniel Kastl daniel at georepublic.de
Tue Jul 16 22:12:57 PDT 2013
On Wed, Jul 17, 2013 at 2:21 AM, Angelos Tzotsos <gcpp.kalxas at gmail.com>wrote:
> Hi Daniel,
> I understand the issue.
> Lets wait for a decision on the UbuntuGIS ppa before including pgRouting
> again in the builds.
Hi Angelos,
I think I found a way to accept either "postgresql-9.1-postgis-2.0" or
"postgresql-9.1-postgis" as dependency, whatever is available.
The packages will soon be published on Launchpad, so with the next build I
hope pgRouting will be installed correctly.
Daniel
> Thanks,
> Angelos
> On 07/16/2013 08:06 PM, Daniel Kastl wrote:
>> On Tue, Jul 16, 2013 at 8:53 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com
>> >wrote:
>>  Hi Daniel,
>>> A decision has not been taken yet, so we use unstable until then.
>>> Probably this will happen after beta1.
>>>  Thanks, Angelos,
>> For pgRouting this makes a difference:
>>     - if "stable" is used, then the PostGIS package name is
>>     "postgresql-9.1-postgis" and all should work already (as it worked
>> before
>>     the change)
>>     - if "unstable" is used, then the PostGIS package name is
>>     "postgresql-9.1-postgis-2.0" and I have to rebuild the pgRouting
>> package
>> So what I'm not really interested in is switching back and forth ;-)
>> Hope that's understandable.
>> Daniel
>>  Cheers,
>>> Angelos
>>> On 07/16/2013 01:49 PM, Daniel Kastl wrote:
>>>     Hi all,
>>>>> As you probably have seen we had some issues with UbuntuGIS packages
>>>>>> last
>>>>>> week, causing build failures.
>>>>>> At this point we are almost back to normal.
>>>>>> Of course this delay caused a slip in beta1 release date.
>>>>>>   Has there been a decision already, which UbuntuGIS PPA will be used?
>>>>> "stable" or "unstable"?
>>>> Daniel
>>> Angelos Tzotsos
>>> Remote Sensing Laboratory
>>> National Technical University of Athens
>>> http://users.ntua.gr/tzotsos
> Angelos Tzotsos
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20130717/1556bfa1/attachment.html>
More information about the Live-demo mailing list
