[Live-demo] OSGeoLive 7.0 status: beta1
Hamish
hamish_b at yahoo.com
Tue Jul 16 22:29:22 PDT 2013
Daniel wrote:
> I think I found a way to accept either "postgresql-9.1-postgis-2.0"
> or "postgresql-9.1-postgis" as dependency, whatever is available.
without seeing your approach, fwiw in the control file Depends line(s)
if you set:
postgresql-9.1-postgis-2.0 | postgresql-9.1-postgis,
it will be ok with either. if both are available it will go with
the first. if that's in your Build-depends: line then
the run-time installation will have to match the build-
time one.
regards,
Hamish
More information about the Live-demo
