[Live-demo] OSGeoLive 7.0 status: beta1
Daniel Kastl
daniel at georepublic.de
Tue Jul 16 22:50:10 PDT 2013
On Wed, Jul 17, 2013 at 2:29 PM, Hamish <hamish_b at yahoo.com> wrote:
> Daniel wrote:
> > I think I found a way to accept either "postgresql-9.1-postgis-2.0"
> > or "postgresql-9.1-postgis" as dependency, whatever is available.
> Hi,
> without seeing your approach, fwiw in the control file Depends line(s)
> if you set:
> postgresql-9.1-postgis-2.0 | postgresql-9.1-postgis,
This is exactly what I did.
But because of lack of sleep and silly mistakes late at night it took
several attempts until it worked finally ;-)
Daniel
> it will be ok with either. if both are available it will go with
> the first. if that's in your Build-depends: line then
> the run-time installation will have to match the build-
> time one.
> regards,
> Hamish
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20130717/f8e45fcd/attachment-0001.html>
More information about the Live-demo
