[Live-demo] OSGeoLive 7.0 status: beta1
Angelos Tzotsos
gcpp.kalxas at gmail.com
Wed Jul 17 00:53:34 PDT 2013
Thanks for the fix :)
I will re-enable pgRouting for the next nightly.
Cheers,
Angelos
On 07/17/2013 08:50 AM, Daniel Kastl wrote:
> On Wed, Jul 17, 2013 at 2:29 PM, Hamish <hamish_b at yahoo.com> wrote:
>> Daniel wrote:
>>> I think I found a way to accept either "postgresql-9.1-postgis-2.0"
>>> or "postgresql-9.1-postgis" as dependency, whatever is available.
>> Hi,
>> without seeing your approach, fwiw in the control file Depends line(s)
>> if you set:
>> postgresql-9.1-postgis-2.0 | postgresql-9.1-postgis,
> This is exactly what I did.
> But because of lack of sleep and silly mistakes late at night it took
> several attempts until it worked finally ;-)
> Daniel
>> it will be ok with either. if both are available it will go with
>> the first. if that's in your Build-depends: line then
>> the run-time installation will have to match the build-
>> time one.
>> regards,
>> Hamish
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
More information about the Live-demo
