[Live-demo] Update OSGeo-Live Project Overviews and Quickstarts - geoserver
Angelos Tzotsos gcpp.kalxas at gmail.com
Mon Jul 29 05:49:37 PDT 2013
Hi Frank,
After a small round of testing, it seems that GeoServer 2.3.4 did not
break any of the [Cartaro, GeoNode, ZOO] that use it in their quickstarts.
The build tested is:
http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-debug-build10503-i386.iso
http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-debug-build10503-i386-log.tar.gz
Can the Cartaro team confirm?
I tested on behalf of GeoNode and ZOO projects since I am involved.
If I forget some other project that uses GeoServer as upstream, please
test and let me know.
Cheers,
Angelos
On 07/29/2013 10:49 AM, Frank Gasdorf wrote:
> Thanks Angelos, looking forward for the new ISO
> Cheers, Frank
> Am 29.07.2013 00:36 schrieb "Angelos Tzotsos" <gcpp.kalxas at gmail.com>:
>> Hi,
>> I see that an hour ago Geoserver was upgraded to 2.3.4 on svn.
>> I am going to make a nightly build with that setting and provide the iso
>> link here soon.
>> Since we are in feature freeze, it is required from downstream projects to
>> confirm that new GeoServer does not break their appllications. In case it
>> does, the upgrade will be reverted for 7.0 and re-applied for 7.5.
>> Cheers,
>> Angelos
>> On 07/20/2013 02:04 AM, Angelos Tzotsos wrote:
>>> Hi Frank,
>>> I would be +1 on the upgrade only if Cartaro and GeoNode that have worked
>>> hard to catch up to 2.3.3 can confirm that their packages work fine with
>>> 2.3.4.
>>> BTW, Inspire plugin is already in the disk ;)
>>> Cheers,
>>> Angelos
>>> On Fri, Jul 19, 2013 at 10:54 PM, Frank Gasdorf <
>>> fgdrf at users.sourceforge.net
>>>> wrote:
>>>> Let me summarize the current state:
>>>> * geoserver is in version 2.3.3 on 7.0
>>>> * we would like to get 2.3.4 on it
>>>> * 2.3.4 will be build and released this weekend
>>>> what's new from my point of view:
>>>> * Translation completed for Dutch, German, Korean and close to is Chinese
>>>> (98%) - will come with 2.3.4
>>>> * INSPIRE plugin made it into release (since 2.3.2)
>>>> * several Security Subsystem Improvements
>>>> * SQL Server performance improvements
>>>> * etc.
>>>> I hope we get 2.3.4 on OSGeo live 7.0 although we already have feature
>>>> freeze. It would be great to get all the translated UI's for GeoServer in
>>>> it because all the translation teams did a great job to (almost) finish
>>>> it.
>>>> Any opinions?
>>>> Cheers, Frank
>>>> 2013/7/19 <cameron.shorter at gmail.com>
>>>> Ian, Frank,
>>>>> I'm not sure if you saw this email?
>>>>> We previously packaged version 2.2.2 of geoserver  and our status sheet
>>>>> shows version 2.3.3 packaged for OSGeo-Live 7.0.
>>>>> On 19/07/2013 8:47 AM, Cameron Shorter wrote:
>>>>>   Now that we have a feature freeze for OSGeo-Live 7.0, could all
>>>>>> OSGeo-Live projects please ensure
>>>>>>     their Project Overviews and Quickstarts [0] are up to date. This
>>>>>> should be quite painless for most.
>>>>>>     1. Update the version number in your Project Overview (if changed).
>>>>>> 2. Possibly mention a new feature or two.
>>>>>> 3. Re-run the Quickstart and ensure each step is still valid, and
>>>>>> screenshots match the implementation.
>>>>>> 4. Update status of the Project Overview and Quickstart to "7.0draft"
>>>>>> in
>>>>>> our status sheet. [1]
>>>>>>     Schedule:
>>>>>    * 29 July 2013 English docs complete
>>>>>> * 05 August 2013 Translations complete
>>>>>> * 26 August 2013 OSGeo-Live sent to the printers
>>>>>>     [0] https://svn.osgeo.org/osgeo/****livedvd/gisvm/trunk/doc/<https://svn.osgeo.org/osgeo/**livedvd/gisvm/trunk/doc/>
>>>>> <https**://svn.osgeo.org/osgeo/**livedvd/gisvm/trunk/doc/<https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/doc/>
>>>>>    [1] https://docs.google.com/****spreadsheet/ccc?key=****
>>>>> 0Al9zh8DjmU_**<https://docs.google.com/**spreadsheet/ccc?key=**0Al9zh8DjmU_**>
>>>>>> RdGIzd0VLLTBpQVJuNVlHMlBWSDhKL****Xc#gid=13<https://docs.**
>>>>>> google.com/spreadsheet/ccc?**key=0Al9zh8DjmU_**
>>>>>> RdGIzd0VLLTBpQVJuNVlHMlBWSDhKL**Xc#gid=13<https://docs.google.com/spreadsheet/ccc?key=0Al9zh8DjmU_RdGIzd0VLLTBpQVJuNVlHMlBWSDhKLXc#gid=13>
>>>>> Cameron Shorter
>>>>> Geospatial Solutions Manager
>>>>> Tel: +61 (0)2 8570 5050
>>>>> Mob: +61 (0)419 142 254
>>>>> Think Globally, Fix Locally
>>>>> Geospatial Solutions enhanced with Open Standards and Open Source
>>>>> http://www.lisasoft.com
>> Angelos Tzotsos
>> Remote Sensing Laboratory
>> National Technical University of Athens
>> http://users.ntua.gr/tzotsos
Angelos Tzotsos
More information about the Live-demo mailing list
