[Live-demo] Update OSGeo-Live Project Overviews and Quickstarts - geoserver
Benjamin Proß
b.pross at 52north.org
Mon Jul 29 07:47:54 PDT 2013
GeoServer 2.3.4 works well with the 52°North WPS.
Cheers,
Benjamin
Am 29.07.2013 14:49, schrieb Angelos Tzotsos:
> Hi Frank,
> After a small round of testing, it seems that GeoServer 2.3.4 did not
> break any of the [Cartaro, GeoNode, ZOO] that use it in their
> quickstarts.
> The build tested is:
> http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-debug-build10503-i386.iso
> http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-debug-build10503-i386-log.tar.gz
> Can the Cartaro team confirm?
> I tested on behalf of GeoNode and ZOO projects since I am involved.
> If I forget some other project that uses GeoServer as upstream, please
> test and let me know.
> Cheers,
> Angelos
> On 07/29/2013 10:49 AM, Frank Gasdorf wrote:
>> Thanks Angelos, looking forward for the new ISO
>> Cheers, Frank
>> Am 29.07.2013 00:36 schrieb "Angelos Tzotsos" <gcpp.kalxas at gmail.com>:
>>> Hi,
>>> I see that an hour ago Geoserver was upgraded to 2.3.4 on svn.
>>> I am going to make a nightly build with that setting and provide the
>>> iso
>>> link here soon.
>>> Since we are in feature freeze, it is required from downstream
>>> projects to
>>> confirm that new GeoServer does not break their appllications. In
>>> case it
>>> does, the upgrade will be reverted for 7.0 and re-applied for 7.5.
>>> Cheers,
>>> Angelos
>>> On 07/20/2013 02:04 AM, Angelos Tzotsos wrote:
>>>> Hi Frank,
>>>> I would be +1 on the upgrade only if Cartaro and GeoNode that have
>>>> worked
>>>> hard to catch up to 2.3.3 can confirm that their packages work fine
>>>> with
>>>> 2.3.4.
>>>> BTW, Inspire plugin is already in the disk ;)
>>>> Cheers,
>>>> Angelos
>>>> On Fri, Jul 19, 2013 at 10:54 PM, Frank Gasdorf <
>>>> fgdrf at users.sourceforge.net
>>>>> wrote:
>>>>> Let me summarize the current state:
>>>>> * geoserver is in version 2.3.3 on 7.0
>>>>> * we would like to get 2.3.4 on it
>>>>> * 2.3.4 will be build and released this weekend
>>>>> what's new from my point of view:
>>>>> * Translation completed for Dutch, German, Korean and close to is
>>>>> Chinese
>>>>> (98%) - will come with 2.3.4
>>>>> * INSPIRE plugin made it into release (since 2.3.2)
>>>>> * several Security Subsystem Improvements
>>>>> * SQL Server performance improvements
>>>>> * etc.
>>>>> I hope we get 2.3.4 on OSGeo live 7.0 although we already have
>>>>> feature
>>>>> freeze. It would be great to get all the translated UI's for
>>>>> GeoServer in
>>>>> it because all the translation teams did a great job to (almost)
>>>>> finish
>>>>> it.
>>>>> Any opinions?
>>>>> Cheers, Frank
>>>>> 2013/7/19 <cameron.shorter at gmail.com>
>>>>> Ian, Frank,
>>>>>> I'm not sure if you saw this email?
>>>>>> We previously packaged version 2.2.2 of geoserver and our status
>>>>>> sheet
>>>>>> shows version 2.3.3 packaged for OSGeo-Live 7.0.
>>>>>> On 19/07/2013 8:47 AM, Cameron Shorter wrote:
>>>>>> Now that we have a feature freeze for OSGeo-Live 7.0, could all
>>>>>>> OSGeo-Live projects please ensure
>>>>>>> their Project Overviews and Quickstarts [0] are up to date. This
>>>>>>> should be quite painless for most.
>>>>>>> 1. Update the version number in your Project Overview (if changed).
>>>>>>> 2. Possibly mention a new feature or two.
>>>>>>> 3. Re-run the Quickstart and ensure each step is still valid, and
>>>>>>> screenshots match the implementation.
>>>>>>> 4. Update status of the Project Overview and Quickstart to
>>>>>>> "7.0draft"
>>>>>>> in
>>>>>>> our status sheet. [1]
>>>>>>> Schedule:
>>>>>> * 29 July 2013 English docs complete
>>>>>>> * 05 August 2013 Translations complete
>>>>>>> * 26 August 2013 OSGeo-Live sent to the printers
>>>>>>> [0]
>>>>>>> https://svn.osgeo.org/osgeo/****livedvd/gisvm/trunk/doc/<https://svn.osgeo.org/osgeo/**livedvd/gisvm/trunk/doc/>
>>>>>> <https**://svn.osgeo.org/osgeo/**livedvd/gisvm/trunk/doc/<https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/doc/>
>>>>>> [1] https://docs.google.com/****spreadsheet/ccc?key=****
>>>>>> 0Al9zh8DjmU_**<https://docs.google.com/**spreadsheet/ccc?key=**0Al9zh8DjmU_**>
>>>>>>> RdGIzd0VLLTBpQVJuNVlHMlBWSDhKL****Xc#gid=13<https://docs.**
>>>>>>> google.com/spreadsheet/ccc?**key=0Al9zh8DjmU_**
>>>>>>> RdGIzd0VLLTBpQVJuNVlHMlBWSDhKL**Xc#gid=13<https://docs.google.com/spreadsheet/ccc?key=0Al9zh8DjmU_RdGIzd0VLLTBpQVJuNVlHMlBWSDhKLXc#gid=13>
>>>>>> Cameron Shorter
>>>>>> Geospatial Solutions Manager
>>>>>> Tel: +61 (0)2 8570 5050
>>>>>> Mob: +61 (0)419 142 254
>>>>>> Think Globally, Fix Locally
>>>>>> Geospatial Solutions enhanced with Open Standards and Open Source
>>>>>> http://www.lisasoft.com
>>> Angelos Tzotsos
>>> Remote Sensing Laboratory
>>> National Technical University of Athens
>>> http://users.ntua.gr/tzotsos
Benjamin Proß
52°North Initiative for Geospatial Open Source Software GmbH
Martin-Luther-King-Weg 24
E-Mail: b.pross at 52north.org
Fon: +49-(0)-251–396371-42
Fax: +49-(0)-251–396371-11
http://www.52north.org
General Managers: Dr. Albert Remke, Dr. Andreas Wytzisk
Local Court Muenster HRB 10849
More information about the Live-demo
